Old 21st April 2010, 11:58 PM   #1
Default 3-way....Where's the gain coming from?!
Guys,
Funnily, even with impedance smoothing circuits in place and an accurate model of the mid and low drivers, there appears to be an enormous gain peak there...surely with Butterworth's there aren't! I can't spot anything other than a first-order crossover anywhere there...unless I'm blind!
Old 22nd April 2010, 01:24 AM   #2
godfrey is offline godfrey  South Africa
I think your graph is showing dB re 1 volt, so your input is about +9db.
Set the input to 1volt and it should make more sense.
Old 22nd April 2010, 01:46 AM   #3
Godfrey...!
I cannot believe this. Someone come along, hit me with a stick. Please.
Brain-fart?! I'm going to hide my head in shame now. That fixed it!
That said, dB is a 'relative' scale and hence input voltage should make little difference...maybe the dB markers are set incorrectly in pSpsice.
20Log(Pout/Pin) is the formula...nowhere is there a 1V level for it to be 'relative' to. It should know that 2.83V is the input and hence, what it ought to be relative to. Apparently not!
Old 22nd April 2010, 02:04 AM   #4
Well it can be: 20Log(Vout/Vin) or 10Log(Pout/Pin),
but often also used is: 20Log(Vmeasured/Vreference),
in which case the "reference" is normally 1 volt.
Sim software tends to work like that anyway.
Old 22nd April 2010, 02:23 AM   #5
Ah! That makes sense...if they set the reference to a default 1V and didn't take ACMag into account! Godfrey, FYI, I was born and brought up in Durban! Family are still there and in Paarl.
It's late at night here, explains the oversight. But - for those using PSSPICE again in the future, hopefully this thread will be of use and stop many's a headscratching!
Forgive me, but to the uninitiated (EE here) such an error in software could cause a serious amount of confusion.
Throwing away open loop gain with an opamp near or at unity gain okapi Pass Labs 3 25th December 2009 01:23 PM
Gain Blockwith Variable Loop Gain Bonsai Solid State 17 11th July 2008 02:40 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Unity Gain Operation (or low gain) Tomo Chip Amps 12 22nd January 2004 01:47 AM
Page generated in 0.08430 seconds (74.05% PHP - 25.95% MySQL) with 10 queries
