Old 20th April 2010, 02:51 PM   #1
ezr1 is offline ezr1  Israel
Talking Altec 605 OB help
hello
i am new here and i need some help ideas
i have altec 605 on ob 100 x90 cm(some kind like "yamamoto" l.s.)
on the top i am using super tweeter pioneer pt- 410
the sound is very good with my 2 mono block quad classic 15w x2
but but the low freq-bass is not so deep etc etc
any ideas recomm/
thanks a lot
ezra
Old 21st April 2010, 06:02 AM   #2
jerome69's Avatar
The ALTEC 605 cannot be use passively as a woofer in ob. Qts=0.25 is too low
1. Add one or two active subwoofers ? if the Altec is used as midrange
2. You cannot get bass with 15W in an ob with a passive crossover, solid state amplifier is recommended 50-200W. An active correction for the bass could work better.
3. Take as inspiration MJK work :
OB Theory
Quarter Wavelength Loudspeaker Projects
Have fun.
Old 21st April 2010, 12:54 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Right, what Jerome said. 100%.
There is some crossover work you can do to get a little better tonal balance out of the 605, but it really needs a woofer for O.B. Just take a look at the rig and the crossover in my thread. Big OB fun. Come hear!
That's the way to do it.
Take the Speaker Voltage Test!
Old 21st April 2010, 01:40 PM   #4
Speakerholic
Cal Weldon's Avatar
Agree with Jerome and Pano.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 21st April 2010, 04:38 PM   #5
Derry is offline Derry  United States
Derry's Avatar
I have the old Altec literature on their speakers and the 605B is rated for 35 watts (50 peak),, says freq response is 20 - 22K when operated in an optimum enclosure,, any higher power amp would be a waste of $$$ as those 605s were some of the most efficient speakers around,,
I use the A500 Voice of Theaters in my HT and even though rated at 35 - 22K I never felt the bass was very strong,, none of the older speaker systems ever offered the real THUMPING or rumbling sound a good sub with a LFE feed does,,
a SVS 13 ultra solved that issue for me,,
Derry
Old 21st April 2010, 11:57 PM   #6
tomp787 is offline tomp787  United States
Hello Ezra,
You can increase the bass response from your open baffle 605 by increasing the amplifiers source impedance. This is described in the Arpeggio article by Morgan Jones. Another place to look for ideas is in the Firstwatt amplifiers by Nelson Pass. Some of Firstwatt amplifiers are current source amplifiers which by definition have high output impedance.
I don't know how loud you like to play your music or your room size so I won't guess what will be the best for you.
Good Luck and Have Fun,
Tom
Old 30th April 2010, 01:55 PM   #7
Default help
i send
and it wasnt replay
anyway thanks a lot
ezra
Old 30th April 2010, 02:09 PM   #8
Pano's Avatar
What did you send and where?
Altec 604 vs. 605 korneluk Multi-Way 4 23rd March 2009 12:50 PM
Altec 811B horns and Altec 414z 12" Speakers xecluded Swap Meet 0 21st September 2008 05:21 AM
Jensen A12 OB + Altec 802-8D Horn Project nullspace Multi-Way 8 30th January 2008 03:02 PM
OB bass bin for Altec 511B/902-8B combo... chops Full Range 32 7th December 2006 08:19 PM
Upgrade Alpine mrd-605? hc_TK Car Audio 1 5th April 2006 03:21 PM
Page generated in 0.10352 seconds (80.75% PHP - 19.25% MySQL) with 10 queries
