What Enclosure for 4x kef B139-1024 and 4xb110?
Old 20th April 2010, 01:26 PM   #1
galop is offline galop  Slovenia
Default What Enclosure for 4x kef B139-1024 and 4xb110?
Hello i have 4 kef b139 and 4 kef b110 speakers.I want to make separate enclosures for this drivers.I like big enclosures and very low bass.What do you suggest?
Old 20th April 2010, 02:38 PM   #2
I write wrong,i want to make separate enclosure for bass and separate for mid,2 x b139 and 2 x b110 per channel.What kind of box do you suggest (bass reflex,transmision line or something else for bass)?Size of cabinet is not problem.
Old 20th April 2010, 03:00 PM   #3
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Moved to Multi-Way forum.
planet10 needs your help:
Let's help Ruth and Dave
Old 20th April 2010, 04:06 PM   #4
event horizon is offline event horizon  England
event horizon's Avatar
If i remember correctly the B139 has a Qts of 0.375 & a Vas of about 3cuft. As it's bass resonance is approximately 29.5Hz why not stuff each one in a 3cuft (3 cubic foot) box tuned by a reflex port to 30Hz
F3 will be at the box tuning frequency, is 30Hz -3Db good enough? If not then tune it lower & expect a more gradual rolloff from a higher frequency.
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 20th April 2010, 05:23 PM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Scott & i did a modern TL for the B139. So far i have drawn up 3 variations. Transmission Line Speakers
A friend has built these ones (he shortened them a couple inches to fit in his room):
He likes them alot.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th April 2010, 07:33 PM   #6
jerryo is offline jerryo  Isle of Man
Hi galop,
try a google search for "Linn Isobarik DMS" They use the B139 in an isobarik loaded cabinet of about 55 litre's or thereabouts. They are famous for delivering really good very low bass in quantity. I have a pair and I can agree with that.
Worth a look for ideas.
Old 20th April 2010, 08:09 PM   #7
a.wayne is offline a.wayne  United States
Sin Bin
Are B139's or such type woofers still available ?
Old 20th April 2010, 08:10 PM   #8
Only on ebay or suchlike as far as i know They are long out of production.
Old 21st April 2010, 11:09 AM   #9
Maybe this design would be ok.I was thinking about coffin sub ,but i need to build 2 ,because i have 4 drivers.but i dont know what will happen if i put 2 coffin subs on the left and right side of the room.(phase interference etc??)
1 cubic feet is 28 ,31 litres?
Old 21st April 2010, 05:22 PM   #10
Yes So effectively you'd need about 85L + port volume & any bracing as well as a bit to add for each driver
If you were driving them via a seperate amp (for the subs) there is no reason why you couldn't alter the phase to any sub to bring the whole lot into time alignment, well with a bit of fiddling about anyway
What Enclosure for 4x kef B139-1024 and 4xb110?Hide this!Advertise here!
KEF B139 as subwoofer andyjevans Subwoofers 53 30th September 2017 09:16 PM
KEF b139 sp1212 data? Tomac Multi-Way 4 23rd April 2016 03:53 PM
Enclosure for 2x kef B139 1024 galop Planars & Exotics 3 11th November 2009 04:07 PM
KEF B139 for sub woofer kennyb Subwoofers 3 7th January 2004 11:45 AM
Kef B139 ... TugaTweaker Swap Meet 0 3rd January 2004 11:22 PM
Copyright ©1999-2017 diyAudio
