i have these drivers, FUSION Electronics ? Car and Marine Audio but it does not list the vas value hence simulations do not work properly, is there a way of working it out from the other values given (like compliance) or a rough value that would be suitable for most 6.5 inch drivers, thanks . I am looking to build very small cabinets for them and need to give them ported enclosures to maintain some of the bass. (hence i need to simulate to work out port lengths and stuff)
#2 |
witha Qts of .7, they are likely to have a large Vas - they will most likely only be suitable for closed boxes.
But if you really want to know, download ARTA: ARTA ARTA Download make this simple jig: ARTA Jig - AudioBlog: A simple loudspeaker measurement jig for ARTA and measure them...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
ok then that is fair enough. i know it has been killed to death, but which drivers would be able to have a small ported enclosure (for max bass for the size) around 3 or 4 inch full range or coax, and the dealbreaker is that any driver would need to be avaliable in the uk without the costomary "twice the value of the item" delivery from the us
#4 |
If you go here Measuring Loudspeaker Driver Parametersthere are two options for finding the Vas parameter. Regards. |
#5 | |
Here is a complete guess at the parameters from what they have published: Fs 56.0 Hz Qts 0.7 Qes 0.77 Vas 13 Liters Re 3.6 Ohms Dia 12.3 cm Xmax 6 mm Pe_max 70 Watts Woofer Calculated parameters Sd 0.01188 m^2 Cms 0.000656 m/N Mdt 0.0123 kg Bl 4.50 T*m no 90.04 dB/2.83V no 86.57 dB/1W Qms 7.700 These are not vented box speakers - anything with a Q>0.4 or so is sealed box only unless you want a huge box and probably lots of distortion from overexcursion.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#6 |
using Ron's numbers in Winisd, I get 35L tuned to 44Hz;
anything smaller will give you a really boomy bass response as an alternative, maybe something like this: Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
| A superior VAS clamp and VAS current limit for the Blameless. | GK | Solid State | 128 | 19th October 2011 03:03 PM |
| low VAS sealed better than high VAS? | matos81 | Subwoofers | 3 | 7th April 2006 11:28 AM |
| Going way under VAS | ralph-bway | Multi-Way | 1 | 28th January 2004 02:30 AM |
| BJT for VAS | JensRasmussen | Solid State | 4 | 1st August 2002 10:37 PM |
| Page generated in 0.07578 seconds (84.89% PHP - 15.11% MySQL) with 10 queries |
