Old 17th April 2010, 09:20 PM   #1
thadman is offline thadman  United States
Default Plasma Loudspeaker Circuit topology, feedback wanted
I'm looking for some feedback on this circuit topology
Right circuit is the ionization circuit. Left circuit is the audio circuit.
The electrodes from both sources will be placed in close proximity to one another. Helium will be directed over the electrodes. The ionization circuit will produce 100kV --> 1MV. Once the air is ionized, the electrodes from the audio circuit (~500V) will begin conducting and a stable plasma will be formed. Once a stable plasma is formed, the ionization circuit output can be turned off. Sound will be produced by varying the current through the plasma.
Any thoughts?
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 18th April 2010, 09:37 AM   #2
http://digikey.com/Web%20Export/Supp...ationGuide.pdf
These new EPC GaN transistors look interesting.
10 EPC1010s operated in parallel for each switch in the DC-DC converter should provide significant current headroom (120 amps @ 200V). However, I believe this may require careful matching of components.
Any reason why these wouldn't work?
High Voltage Direct Drive amplifier for Plasma loudspeaker thadman Tubes / Valves 14 25th August 2011 12:24 AM
High Voltage Direct Drive amplifier for Plasma loudspeaker thadman Solid State 1 5th April 2010 08:19 AM
power acoustic plasma sphere not very plasma-rific scampo77 Car Audio 13 30th March 2010 12:25 AM
Some topology of current feedback amplifier aht Solid State 7 13th August 2005 02:49 PM
JOB circuit topology khayman Solid State 7 31st August 2002 12:13 AM
Page generated in 0.07479 seconds (72.41% PHP - 27.59% MySQL) with 11 queries
