Old 16th April 2010, 08:25 PM   #1
form109 is offline form109  United States
Default Odd Way to Get more Bass From Shelf Stereo System
abit of an Odd Way to get more Bass from a Shelf Stereo System
The Top Woofers are Connected to the Original amp built into the Shelf's Main Unit...and the Bottom Woofers have been Disconnected in both Speakers and Connected to a Subwoofer Plate Amp,and Speaker Level Imput Wired to the Woofer output of the Amp.
has anybody ever done that before?
im Not sure if The Woofer with Bass going to it Negatively Affects the other one...as it Doesnt Move Nearly as much...so essentially the Top woofer is also abit of a Passive Radiator as well as Radiating Midrange.
The Top and Bottom Woofers are Shifted 180 Degrees out of Phase which Eliminates much of the Midbass Boom.
Does this Setup Seem Rediclous?
Old 17th April 2010, 12:53 AM   #2
Inductor's Avatar
Right... it should be wrong.
It look ridiculous, not if it works for you.
Second (third), it's affecting X-over frequencies because you changed impedance of the 2 woofers that were connected in series/parallel as they were before and no more. I'm saying this not knowing anything about it...
Old 17th April 2010, 01:19 AM   #3
im not sure Excactly what you mean there?
it Does Work Fairly Well.....usable LF Extension down to 35
as you can imagine the Limits of the Small 5 and some odd Inches woofer isnt Hard to Reach....loud enough for me.
DIY Shelf Stereo System? form109 Solid State 32 14th October 2010 05:32 AM
Exploring the Insides of a Sony Shelf Stereo... form109 Everything Else 3 14th March 2010 09:01 AM
Low budget FR build for a cheap micro shelf stereo. 5wrms, what driver to go with? nobb Full Range 16 26th October 2009 05:15 AM
On Off pop annoying, odd mix of system. mikee55 Power Supplies 2 28th February 2009 01:01 AM
Odd problem: Decent bass output only at very high gain. jaimegmr Car Audio 9 15th November 2006 04:26 PM
Page generated in 0.07748 seconds (82.42% PHP - 17.58% MySQL) with 11 queries
