diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   replacement diaphram & VC for tweeter? (http://www.diyaudio.com/forums/multi-way/164966-replacement-diaphram-vc-tweeter.html)
mondogenerator 12th April 2010 08:28 PM
i have some 'el chepo mega cheapo' tweeters that im seeking to find replacement domes for.
i havent as yet blown them but i am planning a small franken-tweeter experiment.
the chassis' i have are the fairly standard 25mm VC/dome, with the dome,VC & wiring attached to a bezel which sits between the magnet and faceplate which is the again, fairly standard roughly 4" diameter type.
I am seeking a source of replacement domes that may fill this requirement, once i have the magnetic gap height etc measured out. Any manufacturer, any dome material, im not fussy.
Any help the experts out there may have would be welcome.
Many thanks.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
