Old 9th April 2010, 11:15 PM   #1
Default Aluminum voice coil former glue?
I've got some Morel CDM-54 midrange dome driver, which made buzzing noises when it played 2khz tone.
I've took it apart to look what is wrong with it, and found that the voice coil is not attached well to the aluminum former.
What glue should i use?
Thanks!
Old 11th April 2010, 07:46 AM   #2
A rubberized Cyanoacrylate (CA) glue is what was originally used; use Loctite 4204 or a similar product from Hernon (Quantum 134A). Small bead required - bead diameter should be around 0.2-0.3mm maximum.
Yes, I design and build transducers for a living...
Old 14th April 2010, 01:32 PM   #3
Done this with cyanoacrylate, so far it works fine.
Thanks!
What is the bead and where should i put it? The only thing that rise in my mind about "beads" is the ferrite beads used in electronics for HF noise filtering.
Probably the decorative beads may work too, depending on application requirements
Old 14th April 2010, 01:38 PM   #4
Speakerholic
Cal Weldon's Avatar
The bead he is reffering to is the glue. When you apply it you are "laying the bead".
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 14th April 2010, 02:00 PM   #5
Ah, ok then! There was almost no gap between the coil and former, much less than 0.1mm.
Thanks for clarifying!
Voice Coil Formers... Kapton vs Nomex vs Aluminum vs GF/TIL OlogyAudio Multi-Way 3 1st June 2007 02:27 AM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
glue for voice coil wires malcontent Multi-Way 5 6th March 2007 01:12 AM
Aluminum vs. copper voice coil wire? capslock Multi-Way 7 28th October 2002 03:46 AM
Page generated in 0.07338 seconds (73.08% PHP - 26.92% MySQL) with 10 queries
