I posted the below in another thread, but it has been a long time since I did this calculation and I am suspicious I made a mistake. Please take a look and see where I goofed, thanks! (I think the process is correct, but I just don't believe the 88 Hz figure)
"To get a proper measurement really needs a big chunk of open space. At one job I used to measure transducers mounted in a drop-ceiling baffle, 8 feet above the floor = 2.44m. For a 1 meter measurement distance, this meant I had 2x2.44-1=3.88m before the floor reflection would bounce back to the microphone. Using the acoustic formula v=f*l (in this case, speed of sound = frequency* wavelength) then 343=f*3.88 and f=88Hz. So I would be getting "real" data points every 88 Hz. Anyway, to match that reflection-free distance all around, imagine a half-ellipsoid with the tip on the floor and the equator at the ceiling. The width of the ellipsoid would need to also give 3.88m of clear space. This means roughly the nearest furniture or protrusion of any kind must be roughly >1.9m away. |
#2 |
Nobody?
Let me simplify greatly: if I had, say 8 mS before reflections contaminated the direct sound from a speaker I'm trying to measure, what frequency can I measure down to? (Assuming an FFT measurement system, windowing out the reflections) |
#3 |
this should help:
Frequency, Wavelength, Time and Distance Calculator Seems like you're in the right ballpark, but the impulse response will let you know. |
| Check my math? | Jalex420 | Chip Amps | 18 | 3rd June 2006 08:58 AM |
| double check the math | tenderland | Tubes / Valves | 3 | 27th March 2006 04:48 PM |
| DIY Sub with DAYTON RSS315HF-4 in progress; Can someone check my math? | bcycle | Subwoofers | 18 | 7th February 2006 10:30 PM |
| Can't do the math! | poorstudent | Full Range | 3 | 22nd November 2005 06:37 AM |
| Crossover math check | jmikes | Multi-Way | 6 | 13th December 2004 10:30 PM |
| Page generated in 0.05665 seconds (82.16% PHP - 17.84% MySQL) with 10 queries |
