Old 6th April 2010, 07:54 PM   #1
Default Cerwin Vegas INT 252
Hi all,
I've just bought a pair of Cerwin Vegas INT 252. One of them has a blown horn and I can't seem to find an exact replacement. Can anyone suggest a tweeter to use with them.
I'm using a Dynacord Powermate 1000.
The Vegas are 45Hz-20kHz, 4ohms, 500w.
Thanks in advance for your help.
Beryl
Old 6th April 2010, 11:12 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
It would surprise me a little if C-V didn't have something suitable.
Otherwise, take the driver out of the horn, see if it is screw on or bolt on and look for something that mounts the same with similar impedance/sensitivity.
http://www.cerwinvega.com/manuals/pr...nse_manual.pdf says:
LIGHTBULB PROTECTION CIRCUIT: Your Intense! speaker systems are equipped with a power-limiting circuit on the compression driver, to avoid damage to the device if overdriven. If this happens, a small
flicker of light is potentially visible through the front port vents. If this happens, do not panic. What is happening is that instead of this power going directly to the compression driver (where it would potentially
damage it) it is “absorbed” by a high current light bulb, which dissipates this power by converting it into light.
Perhaps the lightbulb burnt out?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Nytech 252 Phil50 Solid State 6 7th July 2011 12:20 PM
NYTECH CA 252 Schematics Wanted ROCKMANDRAKE Parts 4 10th March 2009 02:24 PM
WTT Amp6 Int. Amp for cheap chinese tube Int. Amp mrdon Swap Meet 2 28th July 2006 11:03 AM
Visaton Vox 252-Performance? phibes Multi-Way 17 19th April 2004 07:22 PM
Page generated in 0.06631 seconds (70.67% PHP - 29.33% MySQL) with 10 queries
