Old 6th April 2010, 12:40 PM   #1
Default XO protyping box: "The Box of Doom"
I just found Keith Kidder's BoD
BoD
( I searched here and found nothing, so I thought I'd post it. )
There's some serious work and expense gone into it, so I guess 'you' would have to be building LOTS of speakers to justify the cost?
With so much component variability, wouldn't too low a Z potentially be a problem for an amp, and what sort of xo topology, ie LR2, Bessel etc would you end up with?
Keith's design and construction is amazing, but wouldn't a 'cheap' active biamped solution be more (cost) effective?
comments? thanks, Grant
Old 6th April 2010, 04:48 PM   #2
frugal-phile(tm)
planet10's Avatar
I'm with you on the last. I got a DCX2496 (and a full set of I/O transformers) to do 1st order prototyping. Once narrowed down, i'll be happy to use aligator clips for acyual passive, i don't do enuff mutliways to make something like the BoD worthwhile.
AudioXpress sells a commercial, budget version of this kind of thing
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th April 2010, 10:55 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Datz nutz!
But the multi-tap inductors are the key to making it all fit. =)
Take the Speaker Voltage Test!
Old 7th April 2010, 12:11 AM   #4
TerryO is offline TerryO  United States
TerryO's Avatar
The BoD has been around a long time. I seem to remember reading about it ten plus or maybe closer to fifteen years ago on the old Bass List. At that time simulation software was "very" pricey and this approach would have been quite viable. I thought it was pretty neat and despite what some may say, it works!
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Line level SE to differential "fix-it" box Iain McNeill The Lounge 0 15th January 2010 05:09 AM
who makes 18" x 12" x horn 3-w box??? mastadon Full Range 2 29th October 2009 08:31 PM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
DIY "speaker box" ("BOOM BOX"). Help needed. MASantos Full Range 6 2nd September 2007 12:00 PM
replacing 12" sub in box with back speaker mounted 6" subs aussiebuddha Car Audio 7 14th October 2006 08:26 PM
Page generated in 0.08171 seconds (73.62% PHP - 26.38% MySQL) with 10 queries
