Old 4th April 2010, 08:09 PM   #1
Default crossover attenuation
I'm going for ready made two-way crossover available locally for my isobaric 4 inchers.The tweeters are Indian Peerless soft-dome ones.The response so far is good except that the tweeters are too bright compared to woofers. since I dont have any data on the drivers and the box size was determined by trail and error.
Is there any way I can measure only the existing crossover(2nd order) and determine values for a L-pad circuit. The attenuation is needed on the tweeter. Thanks in advance
Old 4th April 2010, 08:17 PM   #2
This one?
http://www.sengpielaudio.com/calculator-Lpad.htm
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 4th April 2010, 08:53 PM   #3
Thanks for the link
Old 5th April 2010, 01:01 AM   #4
Loren42 is offline Loren42  United States
Just stick an L-Pad in between the tweeter and the crossover. Then adjust the L-Pad for the desired level. Then measure the L-Pad and substitute fixed resistors instead.
Attenuation nad Solid State 5 3rd November 2009 06:13 AM
crossover attenuation mr. jamie Multi-Way 10 21st March 2009 12:07 PM
crossover/attenuation guidance? TWOJZ Multi-Way 91 9th January 2008 07:43 PM
Attenuation argonrepublic Analog Line Level 5 23rd August 2005 07:22 AM
Page generated in 0.05778 seconds (79.62% PHP - 20.38% MySQL) with 10 queries
