Old 4th April 2010, 01:47 PM   #1
angelfj is offline angelfj  United States
angelfj's Avatar
Default neophyte question regarding spkr polarity
I'm in the process of building a home theater speaker system. The center channel design calls for a Tang Band driver for a tweeter.
Parts-Express.com:Tang Band 25-1166SJ 1" Neodymium Tweeter | tweeter dome tweeter fabric dome neodynium tang band tb speakers
I am accustomed to positive voice coil terminal to be marked with a red paint dot or some other way to distinguish polarity. However, the driver I received has no markings. Is there a way to determine the polarity of this driver without a definite marking?
Old 4th April 2010, 02:42 PM   #2
Pano is offline Pano  United States
Pano's Avatar
It's hard with a tweeter. With a cone speaker you can use a battery on the terminals to see which way it moves. You might be able to see it on the tweeter, but often not. A single AA battery is more than enough.
There are phase detectors and other measuring devices that will tell you, but you probably don't want to get into that.
Why not give P.E. tech support a call or drop them a line? They may be able to help. They can tell you if the wide or narrow tab is positive. I think it's standard, but can't remember which! Anyone?
Take the Speaker Voltage Test!
Old 4th April 2010, 03:12 PM   #3
LCole is offline LCole  United States
I've got a generic driver w/ broad side marked + and narrow lead marked - hope it helps. Also found a crossover from a different project with similar markings.
Old 4th April 2010, 03:18 PM   #4
www.TechGuys.ca | How to: Determine speaker polairity verifies previous post.
Old 4th April 2010, 04:42 PM   #5
Speakerholic
Cal Weldon's Avatar
I have only ever seen the wide spade be (+).
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th April 2010, 05:01 PM   #6
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Wider terminal is "+", narrow terminal is "-"
Hear the real thing!
Old 4th April 2010, 08:39 PM   #7
Pano's Avatar
Oh, yeah. Now I remember. Now that you guys have told me.
Old 6th April 2010, 10:06 AM   #8
angelfj's Avatar
Thank you all for the help. I think I'll put a small dot of red paint on the wide lug just so I don't forget in the future.
best regards!
Capacitor polarity question Original Burnedfingers Tubes / Valves 9 13th November 2009 10:54 AM
Tweeter Capacitor Polarity Question omni Multi-Way 30 19th July 2008 07:53 PM
Newb spkr/passive radiator rebuild question FSULongM Multi-Way 3 17th January 2006 06:53 AM
stupid polarity question. Learnincurve Subwoofers 19 28th January 2005 01:32 PM
AMT polarity question Sjef Multi-Way 0 16th January 2004 12:16 PM
Page generated in 0.09224 seconds (79.06% PHP - 20.94% MySQL) with 10 queries
