Hi
Just started a project using this design with kind help from Alistair (algoart). Not far of finished, just need the right size bolts to fix the speakers to the cut out. Easter Sunday and everywhere is closed. Just have to wait another day to try them out. I think if you click the images they will increase in size. 274.jpg 275.jpg 276.jpg |
#3 |
Wow!
Hi Jim, you really don't hang about! Like the look of the ply by the way, B&Q? Looking great,the design looks better in real life than on paper ![]() Can't wait to see the finished product. Bet you can't wait to get them fired up. Looking forward to hearing your comments on their sound. Alistair |
#4 |
Hi Alistair
The ply was Far Eastern from a local wood merchant. It seems to be quite common to all the wood merchants. Got the ply on Monday last week, all pre cut, so saving a bit of time. The internals took the longest as i cut the bracing and foam myself. Yes i cant wait to try them. Will let you know how i get on. |
#5 |
Hi guys, great work there.
I have a pair of Monitor Gold 12's and have been looking for a cab design, are you willing to share your design? Cheers, Lee. |
#6 |
Hi Lee
I dont see why not if its ok with Alistair as he did the calculations and helped with the design. Will get back to you soon. Cheers Jim. |
#7 |
Just got them hooked up and they are quite imposing. They look smaller in the photo. My room is only 12ft x 13ft so i need to think of the finish to give them a disappearing act. The sound is certainly better with a lovely extended bass with no noticeable boom. Voices and piano sound especially good. I was using cabinets with Jordan speakers which have one of the best midrange you can get but the Tannoy's go even better. They seem to give more air around instruments like hearing reverberation. I don't normally listen in the afternoon, only at night so i may have a better idea of how they sound later. So thanks again Alistair they do sound good even in my small room. Jim. Last edited by Holty; 5th April 2010 at 04:41 PM. |
#8 |
That Onken cab looks a lot like what Tannoy called 'distributed port reflex' as used in the Edinburgh, also with a 12" driver, and the Stirling (10").
The Stirling used a 'variable distributed port' ie the ports could be adjusted by sliding a panel over them, leaving the ports fully open, partially or fully covered. |
#9 | |
Jim. |
#10 |
The design came from a mixture of ideas: The Tannoy distributed port as in the Kensington Inspiration from the Mini Onkens at Planet 10 The Onken Calculator. Links to all of these can be found: Monitor Golds Thomo, Happy to share design, contact either myself or Holty and we'll email the bits to you. |
| Tannoy monitor RED 12'' cabinet | marin_iskra | Full Range | 4 | 11th November 2008 09:51 PM |
| backloaded horn cabinet for 12" tannoy monitor gold | angeloitacare | Multi-Way | 5 | 5th December 2007 11:43 AM |
| Treating Tannoy Monitor Golds | Robert F | Multi-Way | 5 | 7th September 2007 02:36 PM |
| Tannoy Monitor Gold Type LSU/HF/12/8 | Osteele | Swap Meet | 0 | 2nd April 2006 03:24 AM |
| What to do about Tannoy Monitor Golds | mgoedeke | Multi-Way | 13 | 12th March 2003 10:58 AM |
