Old 4th April 2010, 03:18 AM   #1
anannra is offline anannra  Canada
Default Extremis 6.8 with w3-871....... hmmm...
Went rummaging through my stash of drivers the other day and found that I have a pair of Adire Extremis 6.8's and eight tang band w3-871's. So I got to thinking...... why not run 4 871's open baffle with the 6.8's helping out in the bottom end in their suggested 21 li vented cab, and x-overed at 300Hz.
Thoughts ? Suggestions ?
TIA
Anoop
Old 4th April 2010, 04:38 AM   #2
Speakerholic
Cal Weldon's Avatar
Yes, get yourself a plate amp for the Extremis and run the TB's off your regular amp and you'll likely be a very happy man. I run two Extremis in this box accompanied by a couple Fosters and am happy about everything but the power handling about the satellites. They sound so good that I want to turn it up and...
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 5th April 2010, 12:39 AM   #3
Neat set up.
I was actually thinking of something more conservative. Essentially I was planning to build the 21li enclosure for the 6.8 and extending the baffle another 18 inches higher to mount 4 w3-871's in an open baffle array sort of thing. With the x-over being around 300hz, I imagine I could run plenty of power into it and not have to worry too much about bottoming out the 871's.
Alternatively I do have some budget for a higher grade mid/tweeter combo or put in a better full range driver, while still keeping the 6.8
Speaking of plate amps, are there any decent 2 channel plate amps out there with x-over point adjustable down to 300hz ?
TIA
Anoop
W3-871 replacement e_fortier Full Range 7 1st October 2008 03:06 AM
is the Tangband W3-871 the same as W3-871S michelevit Full Range 11 6th December 2006 07:09 AM
W3-871S same that W3-871? matos81 Full Range 8 20th March 2006 04:35 PM
Dealer for W3-871 jmikes Full Range 2 22nd December 2004 05:24 PM
help... please....Tangband W3-871 yepper Full Range 4 17th December 2004 04:06 AM
Page generated in 0.07257 seconds (72.15% PHP - 27.85% MySQL) with 11 queries
