Hi guys,
I am busy building some speakers using a set of HIVI 6.8 and some old sony tweeters (till I can get something worth while) I am driving them through a chip amp (td2050). I am tuning the port to 44 hz. So far, they sound pretty good considering they are a mock up. The box is not sealed properly, nor is it padded. However the bass response is not quite right. It seems a little low and requires as fair bit of EQ to get it up and then it seems to lack a bit of bottom end. The port I am using is 50mm and 17.9mm long using the winISD calc. Should I try a longer or shorter port? I dont have any measuring equipment so I am using my ears at the moment. Any advice? |
#2 |
Interesting project. You don't mention the type of tweeter/impedance what is a big flaw, like so many other posters, when they ask questions. I assume that your woofer driver is this one
HiVi D6.8 6" Poly Bass/Midrange Shielded There's this nice project with your driver and I assume you want to make one similar, what's your objections. Totem Acoustic - Columns - Forest |
#3 |
This driver HiVi D6.8 6" Poly Bass does not a very high SPL, more close to 82/83dB. With a different alignment you can get maybe more peaks, that's all, and have to adjust for living room. The ext. size is similar to the "Totem", with BR/Port on the same side as drivers, 38L/38Hz alignment. I did not check Xmax on this config. but should not be that bad.
You can use a L1 Air Core Coil (Erse type #EAC34-18-2000) on the woofer and a RLC circuit to smooth the woofer peak in parallel with L2 Laminated Core Coil (Erse type #ELC54-18-8500) and in place of C3 cap (3.70uF) you can use a (smaller only) 3.6uF cap that you can find. This speaker X-over is using a Visaton (G 20 SC 8 OHM) tweeter with nominal impedance Z=8 Ohm (Rdc=4.8 Ohm). This his very important when changing your xover for your speakers because it all changes when using different drivers. |
#4 |
Woofer is at ~64cm from bottom of the baffle and tweeter at ~79cm, port at ~25cm all aligned in the middle of the front baffle. The drivers are also in phase from ~400Hz to 8000Hz, as you can see from graph#2, important for a good response and imaging (less nulls).
#5 |
HI Inductor
The tweeter came out of a pair of old sony desktops. they are 12ohm. They are used a simple cap for crossover and I have left them as is. I left out the info as the highs and mids all sound fine I wired the pair in parrallel giving the a 4.8 ohm resistance. Low, I know, but for the levels I am playing the amp doesn't really seem to mind. Also forgot to mention, the Box I am using is 14 liters. Thanks for the response! Travis |
#6 |
Utlimately, I want to bi-amp the system and use an active cross over, either via PC or build a linkwitz type... but that will come later
With regards to the bass response, I am guessing I got my port wrong. I am a complete beginner, so please forgive any holes in my logic, but the bass reflex should allow the driver to get a little further down into the bass freq's, which is what seems to be missing in my current config. My main question really is how does having a port that is too long or too short affect the bass? |
#7 | |
#8 |
let me have a look at the value of the cap being used on the tweeters and get back to you.
Thanks a bunch man, much appreciated! |
#9 |
The cap is 1.5 uf....
#10 |
I would ask that you actually measure the frequency response of the cabinet, but that is not a trivial request.
Still, simply listening to a speaker is not the best way to qualify the quality of a speaker. You need measurements to act as a reference for a path to improvement and to spot problems with the system. Also, speaker placement in the room, baffle step diffraction, and room acoustics all play a big part on how the system sounds. |
| Dipole bass or Ripole Bass? | MJL21193 | Subwoofers | 13 | 15th September 2008 07:42 AM |
| any electric bass players? im building a bass guitar cab | KOA | Instruments and Amps | 27 | 30th April 2007 03:49 PM |
| Wow ! Bass from no bass ....! | ashok | Subwoofers | 14 | 15th November 2006 10:59 PM |
| DBA (dual bass arrays) and active bass traps | capslock | Subwoofers | 3 | 20th August 2006 12:52 PM |
| For all Bass Junkies out there (Behringer Bass processor usage report) | VEC7OR | Digital Line Level | 5 | 27th October 2003 09:18 AM |
| Page generated in 0.11022 seconds (82.07% PHP - 17.93% MySQL) with 11 queries |
