good 10" woofer
good 10" woofer
Old 13th June 2003, 11:59 PM   #1
jimsdaho is offline jimsdaho  Canada
Default good 10" woofer
I bought an old pair of sony speakers, I'd like to use the cabinets just replace the woofer the tweeter. What is a good 10" woofer, not too expensive.
Old 14th June 2003, 05:11 PM   #2
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Default These look pretty nice . . .
Found these while looking for subs (they're not subs). http://cgi.ebay.com/ws/eBayISAPI.dll...&category=3276
Old 15th June 2003, 06:23 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
good 10" woofer
Default Re: good 10" woofer
Is something wrong with the existing bits... where in BC are you?
And welcome to the forum
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th June 2003, 06:26 AM   #4
frugal-phile(tm)
planet10's Avatar
good 10" woofer
Default Re: These look pretty nice . . .
The guy seems to have tons of those surplus Klipsh (i had a long email conversation a while back with a fellow about these) ... the Q is really low so getting a box to work can sometimes be problematic.
But they sure are pretty.
dave
Old 15th June 2003, 08:53 AM   #5
I live in Courtenay, not too far away, thanks for the welcome I've been reading lots on here, great forum. I want to replace the woofer because they are low wattage 50 and 45, one of them was replace with diff wattage than the other and b) I put my finger throught the outside edge of one (pretty weak) and c) they didn't sound very good. I was planning on buying some PSB image speakers, but thought I'd try some diy might be a cheap solution. if they aren't good enough for my ht then I can use them a B speakers in another room
Old 15th June 2003, 04:38 PM   #6
frugal-phile(tm)
planet10's Avatar
good 10" woofer
Another island boy I don't get up to Courtney very often, but a friend's wife has family there and is up often (ie a place for hitch-hiking bits)
So the boxes have mismatched bass drivers, and one has a failing surround. How big is the box? You don't want to spend too much on them, so maybe some recycled drivers are caled for.
dave
Old 15th June 2003, 09:18 PM   #7
The box is aproximately 10x12x22
These were suggested py parts express
Part Number:
290-088
PIONEER W25GR31-51F 10" BUTYL SURR WOOFER Power handling: 90 watts RMS/130 watts max * Voice coil diameter: 2" * Impedance: 8 ohms * Frequency response: 26-6,000 Hz * Magnet weight: 30 oz.. * SPL: 90 dB 1W/1m * Vas: 4.77 cu. ft. * Xmax: 3.0mm * Qms: 4.17 * Qes: .36 * Qts: .34 * Fs: 26 Hz. $44.95 EA
Part Number:
296-105
AUDAX PR240Z0 10" AEROGEL WOOFER Power handling: 100 watts RMS * Voice coil diameter: 2" * Le: 1.11 mH * Impedance: 8 ohms * DC resistance: 6.5 ohms * Frequency response: 35-2,000 Hz * Fs: 35 Hz * SPL: 90.0 dB 2.83V/1m * Vas: 2.90 cu. ft. * Qms: 11.37 * Qes: .39 * Qts: .38 * Xmax: 4.0 mm
price $90 ish I think
I want to probably put in new tweeters as well.
I will need a new Xover as well???
Old 15th June 2003, 11:41 PM   #8
frugal-phile(tm)
planet10's Avatar
good 10" woofer
The box is aproximately 10x12x22[/QUOTE]
So about 1.5 ft^3
PIONEER W25GR31-51F ....
I thot you said cheap 10s
Even with the crazy crash of the USD the 1st are going to end up being close to $80-90 CAD landed and the Audax i would consider a higher end driver -- certainly would be considering a new box, tweeter, & XO for those (hey that's a start from scratch project). It is also a question whether the 1st one would be happy in your box... where is KelticWizard when you need him... he can look at the specs and give a good idea of required box size off the top of his head. Also whether one of these new woofers are designed to extend as far up as the older paper cone extended range woofers were designed for.
If you are interested in something recycled -- and much cheaper -- send me an email.
Any chance of pics of the existing box & drivers?
dave
Old 16th June 2003, 12:15 AM   #9
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
good 10" woofer
The Audax needs about 50l, (no idea what that is in cubic F, sorry) with a ported box, and about 75l minimum for a half decent sealed box, and that will take you into the 30s.
As Dave said, the Audax is a very good driver, and worthy of it's own project, ( I know, I use them currently in my main system), but you could always get them, and "run them in" in your old boxes until you were ready to upgrade. But be aware, they don't really go much above 1KHz usefully.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 16th June 2003, 12:47 AM   #10
My bro has a digi cam I will get pic as soon as I can.
"Not too much money" at most $200-$300 Cdn
for both speakers, but I want to get the tweets and Xovers etc for that price. If you think decent recycled ones would sound good then for sure Im interested.
The woofers I listed were recommended for a sealed box of the dimensions of mine, 8ohm
On a slightly diff topic, I also got an old sony amp with them, wondered if it might be of some use? I'll put the model # later and details later gotta go for dinner
good 10" wooferHide this!Advertise here!
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 11:50 PM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 07:07 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 03:29 AM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 08:54 AM
8" poly woofer AUD$29. Unusually good. Circlotron Multi-Way 2 6th January 2003 03:09 PM
