Old 2nd April 2010, 02:14 PM   #1
Bogwan is offline Bogwan  United States
Default Single Capacitor or Two in Series?
I have implemented a 1st order electrical filter on a Seas H1189 tweeter in a 3-way system using a combination of 4.7 uF and 5.6 uF capacitors in series, giving a theoretical value of 2.55 uF. I’m pleased with the results sonically, but I have a feeling that a single capacitor would sound better yet. The advantage of the series combination is that I already own the capacitors, and the 4.7 uF value is a Mundorf Supreme leftover from another project that I’d like to make use of. The 5.6 uF is a Dayton 1%. Would I be better off substituting a single 2.7 uF cap for this combination? Thanks in advance.
Old 2nd April 2010, 02:23 PM   #2
I would avoid capacitors in series at least in the "final" version.
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 2nd April 2010, 02:54 PM   #3
pos is offline pos  Europe
pos's Avatar
Or you can put 9V between the two caps (with a 2 or 3Mohms resistor)/
Do a search for "charge coupled" or biased caps, both here and on audioheritage.org
series capacitor values.. smithie Tubes / Valves 3 27th March 2010 12:54 PM
Capacitor in series - Resistor across ? McIntosh Man Tubes / Valves 4 6th March 2010 01:26 PM
Series or parallel capacitor for bass X-over zebra100 Multi-Way 2 15th May 2009 08:43 AM
The SIngle Capacitor thread ... Madmike2 Multi-Way 4 23rd July 2005 04:35 AM
capacitor in series with pot, no bass. kmj Chip Amps 2 29th March 2005 11:28 AM
Page generated in 0.07183 seconds (75.42% PHP - 24.58% MySQL) with 10 queries
