Old 1st April 2010, 01:58 AM   #1
pulexirritans's Avatar
Default Intentional misalignment of vented enclosures: sacriledge?
Does anyone know if high end audio manufacturers intentionally misalign their vented boxes to give their speakers a more robust sound? I.e. raising fb a little to get a bump in the bass before it rolls off?
I've noticed when I look in Stereophile that the typical well regarded high end speaker has a ~5 db or larger bump in the bass region. For example, the B&W 802D has roughly 7 db of "boom":
http://stereophile.com/images/archiv...205802fig4.jpg
I was thinking this could be in part due to Stereophile's measurement technique, but some other speakers they review have no "boom" at all. e.g. Dunlavy SC-IV/A:
http://www.stereophile.com/images/ar...t/D4afig03.jpg
So does anyone know how manufacturers accomplish this bump in the nether region? Do they simply use a woofer that is more efficient than the midrange? Or do they intentionally misalign the woofer? Or is it a combination of both?
I know this is sacrilege, but I've decided I'd like my next set of speakers to have a little extra bass built into the frequency response. When I listen to a speaker with ruler flat response, I find myself reaching for the tone controls....
Old 1st April 2010, 03:03 AM   #2
re:'do they intentionally misalign the woofer' - well, I won't point fingers, but it's a perfectly legitimate way to get the kind of reponse you like, although IMHO > 3dB is overkill... You can see how to do it by playing with models in Unibox or Winisd, but a tone control is more easily reversible if you change your mind....
(I get my bass fix by bi-amping & winding up the level on the woofer amp)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 1st April 2010, 03:18 AM   #3
Speakerholic
Cal Weldon's Avatar
Nothing wrong with that. Ever notice how popular the active woofer is these days. No secret there.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st April 2010, 05:19 AM   #4
Most of the time the measurement bump you see in the speaker measurements is entirely due to measurement error. You CANNOT stitch a nearfield measurement to a farfield measurement and expect to get an accurate representation of the true speaker performance. It is nonsense to do so other than as a comparative technique. Even then, since the degree of error is dependent upon the cabinet size and splicing frequency, the comparison accuracy is limited.
There are ways around this, but they require a clear understanding of the limitations of the various errors introduced by the various measurement systems and techniques, and how the test signals interact with the speaker under test.
Measuring speakers with sufficient accuracy to properly represent the acoustic performance and how that relates to the listening experience is fraught with problems.
The preponderance of computer based measurement systems these days, while of advantage in reducing the cost of entry for making measurements, is a two edged sword. It makes people think that they know how to measure a loudspeaker and how to draw conclusions from these measurements, whereas a lot of the time they are drawings conclusions contaminated by measurement errors.
When there is no measurement bump in the above quoted measurements, it is either because there is no bump, ie the speaker is designed for boundary reinforcement, or the cabinet size is such that the 2pi/4pi transition frequency is above or below the splicing frequency. But you will never know for sure unless you know a lot more about the system under test.
Andrew
Old 1st April 2010, 06:18 AM   #5
chris661's Avatar
I'd say most commercial designs would employ the idea. Look at the music most people listen to. Certainly where I'm standing, there's a lot of thuds, and someone singing, with limited talent. People listen to how their tracks are meant to sound, ie, flat response, reasonable volume, and they hate it, because it doesn't hit you in the chest. Doing so is easy enough to do - boost the 50-90Hz region a little and you're there. Most people look for that, so, in order to address the market and sell more products, they put that bump in the response.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 1st April 2010, 07:32 AM   #6
I think it's important to note that we're not talking about Britney Spears being played through Bose. We're talking about high performance, high dollar loudspeakers made by highly respected companies. If it really sounds so bad then why do these manufacturers do it?
I can't recall anyone ever calling an NHT speaker boomy and yet their speakers have plenty of extra low end (according to stereophile measurements)
Classic Three:
SB-3:
Even Dynaudio is "guilty":
Reading the loudspeaker cookbook (or talking to your average speaker builder) would have you believe that these speakers sound like a Sony Xplod tub of lard. Clearly this is not the case....
Old 1st April 2010, 07:44 AM   #7
Andrew
Sorry, missed this post. So you're essentially saying their measurements are worthless?
Old 1st April 2010, 08:05 AM   #8
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
There's nothing to say you have to follow the textbook alignments.
In fact none of mine do (even with BSC) and are tweaked to suit my taste, room and partnering equipment. Generally my ports are approximately 0.7 x the Fb calculated length with the raised tuning frequency to give a bump but does it? Read this.
Troelsgravesen vent tuning tests
No longer DIY active
Old 1st April 2010, 09:00 AM   #9
Ouroboros's Avatar
I agree that even well-respected speaker manufacturers do this, though when I asked one why, I was told they would prefer not to, but it was what the market expects!
I find that I simply cannot tolerate any bass-reflex loudspeaker these days, even the high end ones from B&W. (And a lot of sealed boxes sound as if they have Qs over 1.0) Why the market expects a £2000 speaker to sound like some Hoon's sound system in his pimped-up VW Golf is totally beyond me.
<rant>And don't get me on about people who put excessive so-called baffle-step compensation in the speakers either!
</rant>
Old 1st April 2010, 09:16 AM   #10
What i did often is the contrary: Align for smooth rolloff and compensation
of room gain, which is not accounted for in the alignments found by
Thiele and Small. This is also a well known fact and so "misalignments" in
both directions "boomy/smooth rolloff" are quite common.
Since it is practice to modify alignments according to preferences and
room acoustics there is no "misalignment" at all, as long as it is not
overdone.
But i must admit that commercial alignments are often too boomy
in my impression and that causes problems in most listening
environments.
In earlier days i did sometimes "tuning" for commercial speakers bought by
friends, and one measure was often to modify the BR alignment to
more smooth rolloff. Once my "clients" got accustomed to that,
they were happy in most cases.
Best Regards
Oliver, RFZ believer (?)
www.dipol-audio.de
Closed Vs Vented Enclosures rollin24's Subwoofers 50 6th July 2006 06:49 PM
Vented Enclosures - What type is this? nrgy Multi-Way 8 29th March 2004 08:21 AM
Sealed vs Vented Enclosures bradley Multi-Way 21 10th January 2004 05:19 AM
Vented enclosures: ports at the front or rear? Sud Multi-Way 4 17th September 2002 07:49 AM
Page generated in 0.13100 seconds (84.68% PHP - 15.32% MySQL) with 11 queries
