Old 31st March 2010, 11:23 PM   #1
norman bates's Avatar
Default Aurum Cantus ribbons ?
Anyone have experience with their nicer stuff ?
especially the g1 ?
I've been hunting for stuff, and find the review for the aurum Cantus Volla...
Norman
Old 1st April 2010, 01:10 AM   #2
zelgall is offline zelgall  Canada
I have a pair of G1s. They don't seem as efficient as the specs suggest. I tried to mate them to a pair of Altec Model19s with mixed results. Also, they sound better if rolled off above 8K. Otherwise a pretty good ribbon.
Old 1st April 2010, 01:20 AM   #3
I was thinking 24db LR active crossover at 2khz..............
I'll figure out mid/woof later on.
Norman
Old 1st April 2010, 02:46 AM   #4
They're fairly pricey to base a system around. I got mine as a closeout from CSS in Vancouver BC for a substantial discount. It might be worth shopping around for alternatives if you haven't pulled the trigger as yet.
Old 1st April 2010, 03:48 AM   #5
Ribbons can be quite fragile when used active, one amplifier pop switching on or off will kill it instantly.
I use Fountek JP 3.0 active as super tweeters (from 12kHz) and protect it with a passive 18dB high pass filter set about an octave below xover. Worked so far…
Btw my Founteks look remarkably similar to Aurum Cantus G2, a lot cheaper though!
Old 1st April 2010, 11:34 AM   #6
I ordered an Arum Cantus G2, I believe, form PE and returned it. It seemed to be defective. I ended up getting a Fountek which has worked out quite well.
Old 1st April 2010, 01:55 PM   #7
doug20 is offline doug20  United States
I compared the Artum Cantus vs the Neopro5i and I couldnt find anything better so I went with the Neopro5is...I love them. Crossed over at 2KHz with the DCX (LR24).
I always put a cap (36uF) on my ribbons.
Old 1st April 2010, 02:10 PM   #8
Another nice feature of Founteks is that if you buy two you'll get a matched pair.
At least I got from the german retailer I ordered mine from.
Old 1st April 2010, 07:53 PM   #9
ah, thanks for the tip on fountek.
Old 1st April 2010, 08:11 PM   #10
HI ALL
It the best sounding loudspeaker ,I have in my speaker
you can see it on my homeside
AudioHagel
love from
Audiohagel
FS: Aurum Cantus G2 Ribbons Silver MINT Spiritzly Swap Meet 4 7th December 2006 03:14 PM
Aurum Cantus ribbons - gainclones or class A rick57 Multi-Way 0 5th May 2006 06:30 AM
FS: Aurum Cantus G3 ribbons jeff mai Swap Meet 4 25th July 2004 10:40 PM
Aurum Cantus ribbons . Are there...? Lito Multi-Way 0 15th August 2003 01:05 AM
Page generated in 0.10975 seconds (82.51% PHP - 17.49% MySQL) with 10 queries
