Old 30th March 2010, 11:28 AM   #1
anilva is offline anilva  India
Default Need advice on OB with Tone Tubby
I am in the process of making a OB with one 12" Alnico Tone Tubby (8 ohms) crossing over to a 8 ohms Fostex FE126E.
I intend to use a 1st order passive crossover. My plan is to crossover around 500Hz from TT to Fostex. Any suggestions/comments/advice on the crossover point?
My design is based on:
Tiny Alnico Open Baffle
but with a fostex instead of a Lowther.
Thanks in advance.
Cheers.
Old 30th March 2010, 01:04 PM   #2
Josephjcole's Avatar
How loud do you like to listen? A 4.5" cone with less than .5mm xmax isn't going to be able to play very loudly with out distortion in the situation you describe. Maybe a 12 db/octave crossover?
Joe
Old 30th March 2010, 04:59 PM   #3
Joe
Loudness is not a criteria for me. I am looking at transparency and soundstage from a OB. Fostexs are pretty efficient as well.
Cheers.
Old 30th March 2010, 05:20 PM   #4
Cheers.
Sure thing. I just did a quick estimation and it looks like the fostex exceeds xmax at 5watts. I'm not trying to discourage you, just want you to be aware of the limitations. I imagine it could be quite nice within those limitations. I'm afraid I don't have any experience with open baffle so I can't really help you there. Have you read MJK's write up with fostex/eminence open baffle? I imagine you can find most of the info you need there.
Best of luck
Joe
Old 31st March 2010, 12:31 AM   #5
holdent is offline holdent  Canada
I get a little more than 7 watts will exceed the xmax of the FE126E between 70 to 100 Hz with a 1st order xover at 500 Hz. The simplest way around a possible xmax limitation is switch the xover to a 2nd order at 500 Hz. Then the only real limitation is the ultimate power handling of the FE126E. Note that at 15 watts (the Fostex-rated input power of the FE126E) the driver should be producing about 103 dB at 1 m simulated. I used the FE126E measurements from Fostex FE126E + rather than the Fostex published data to run the sim.
I tried simulating the Tone Tubby in an OB using the data from http://www.hempcone.com/pro/pdf/TT%20Spec_'s%200609.pdf but for MJK's MathCad files I also need the Bl, Sd, and Le which aren't provided. The 16ohm version may be better because its Qts is a more OB-friendly 0.9 (rather than the 8 ohm version with a Qts = 0.56). However, if I'm reading the data sheet correctly, both versions have a high Fs (100 Hz and 120 Hz for the 8 and 16 ohm versions respectively). You won't get deep bass from these speakers without some bass boost.
I hope this helps.
Old 31st March 2010, 03:23 AM   #6
I hope this helps.
Thanks. This helps a lot. I have known earlier that 16 ohms version has higher Qts but chose not to go with that due to my amp limitations. I need to make do with 8 ohms. I did plan for a sub woofer reinforcement considering the high Fs of TT.
My question primarily is around the crossover point I need to pick from where TTs pick up and Fostexs leave. TTs are known to go upto 1K I guess without beaming issues, therefore does it make sense for the crossover point to be little higher than 500Hz and may be 800Hz? Thanks, I can look at 12 dB crossover to avoid xmax of Fostex.
Old 31st March 2010, 03:59 AM   #7
I think that you're better off keeping the xover to the FE126E at around 500 Hz and consider looking for a different woofer than the Tone Tubby.
Frequently to get a smooth transition from the bass driver to full range driver the xover points have to be quite different. In MJK's OB study at http://www.quarter-wave.com/OBs/OB_Design.pdf, the crossover points were set at 200 Hz and 500 Hz. Josephjcole earlier referenced his work - it will likely help you alot to look it over. Martin has an excellent discussion about woofer selection. [Note that some have disagreed with Martin's use of high Qts drivers and prefer to use lower Qts drivers with bass boost].
Old 20th April 2010, 06:56 PM   #8
So I am going ahead with a design which has a crossover of 200Hz for the woofer and the Fostex FE-126E being crossed over at 500Hz. Both crossovers will be 12 dB/Octave. The Fostex going to be mounted little off-centre and mirro images are going to be made for Left and Right.
Cheers.
Supravox and/or Tone Tubby OB zmyrna Full Range 20 15th May 2010 11:34 PM
Help to choose between Alerion & Pma6 Ob with "Tone Tubby" AlNiCo HPH Full Range 1 27th July 2009 08:34 PM
Filling the gap -- Tone Tubby ? Sjef Multi-Way 8 18th July 2008 03:06 AM
Anyone try the 8" Tone Tubby? Caferacer Full Range 0 12th December 2007 02:53 PM
tone tubby 8" sumacSK Full Range 2 30th May 2007 09:14 AM
Page generated in 0.11384 seconds (84.59% PHP - 15.41% MySQL) with 10 queries
