Old 28th March 2010, 08:28 PM   #1
jayeph is offline jayeph  United States
Default Please help an amateur diagnose tweeter issue (Vifa XT25)
Hi everyone, I just purchased a pair of Meadowlark Kestrel 2's with the Vifa XT25TG30-04 tweeters.
However, unfortunately one of the tweeters is completely dead/silent. No static/hiss. The seller won't cooperate with me on getting it fixed and insists that it's "shipping damage".
My question is, how can I confirm if it's dead or just a loose wire maybe? I unscrewed the dead tweeter and the wires look connected though. I have no problems ordering a replacement XT25 for ~$40, but I've never installed a tweeter before and I was wondering if it's as simple as soldering/plug-n-play'ing the new tweeter. Do I need to replace both at once so they're matched/have the same hours?
Sorry for the newbie questions, thanks in advance.
Old 28th March 2010, 08:52 PM   #2
mjf is offline mjf  Austria
hello.
you can disconnect one wire from the tweeter
and measure the coil res with a multimeter,it should show a few ohm.
if it shows open circuit the tweeter is probably dead.
greets
Old 28th March 2010, 08:55 PM   #3
thanks for the reply, excuse my ignorance but how do i go about doing this? i'm very new to speakers & electronics but i do have a multimeter
by disconnect, do you mean i need to cut off one of the wire connections? where would i put the prongs to read the ohm?
Old 28th March 2010, 09:13 PM   #4
yes, i would cut off (or desolder) one wire ..........because i don't know your crossover,there could be built in a coil or a res in paralell.........
and the two prongs at the place where the two wires are connected at the tweeter.
Old 28th March 2010, 09:23 PM   #5
so i disconnected one wire, and i just touched the prongs to the two tweeter posts, with music playing
the meter did not move at all
Old 28th March 2010, 09:50 PM   #6
does this mean open circuit/dead tweeter?, from what i know it's a transmission line speaker w/ first order crossover
if so, can i just buy 1 replacement tweeter or do i need a matched pair?
also, one more question, is there any way i can find more info on what caused it to die?
i want to find out if the seller sold me speakers w/ a dead tweeter, or that it actually somehow damaged when shipping to my house.. can a loose wire or anything during shipping cause a dead tweeter?
Old 28th March 2010, 10:55 PM   #7
Andersonix's Avatar
Who told you to have music playing? Anyway, it doesn't matter. Buy a pair of replacement voice coil assemblies (maybe from Madisound?) and ask a handy friend to just replace both.
Old 28th March 2010, 11:00 PM   #8
Shaun is offline Shaun  South Africa
Shaun's Avatar
Unless you can see visible evidence of damage (like a scuff mark, indentation or scratch), it is highly unlikely that your tweeter was damaged in transit. Were they not protectively packaged, anyway?
Switch your multimeter to ohms (might be indicated with an omega symbol), and the range to 200ohms (or the next higher setting above 10). You can test that your meter shows zero ohms when you touch theprobes together, and infinity or "OL" when not connected. After disconnecting at least one of the tweeter leads, apply the probes to the tweeter connection lugs. The reading should be in the region of 4 to 7 ohms, or thereabouts. If it shows "OL", the voice coil has gone open circuit.
But before doing all that, it may be useful to check the connections around the crossover. Sometimes dry solder joints can develop; moving the equipment around may cause them to go completely open circuit.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 28th March 2010, 11:00 PM   #9
i'm new to this, i wasn't sure... you can test it with speaker cables disconnected?
what do you mean by voice coil assemblies? i don't need to replace the tweeter? again please excuse my ignorance and bear with me
Old 28th March 2010, 11:06 PM   #10
yes they were in packed well, i just have a feeling the seller already knew it was dead and sold it to me anyway... now he's telling me that shipping damage caused the tweeter to die
when i read the tweeter resistance w/ the multimeter, am i suppose to have the speaker cable disconnected? does it matter?
i have on way of getting to the crossover... the cabinet is very narrow and i'm not sure how to open it
thanks in advance for the help
Vifa xt25 tweeter Per Nielsen Multi-Way 67 12th March 2010 05:58 PM
Dayton RS 7"/ Vifa XT25 tweeter Crossover LukeDuke Multi-Way 4 13th February 2008 05:39 AM
Attempting to diagnose pioneer PDR-05 cd recorder issue, won't recognize discs. 240z4u Digital Source 10 30th October 2006 11:59 PM
Choosing tweeter SS 9500, 9800 or Vifa XT25 ? santi Multi-Way 5 21st January 2005 08:41 PM
opinions on the new VIFA dual conc. tweeter XT25 grataku Multi-Way 25 5th June 2002 06:10 AM
Page generated in 0.11006 seconds (83.86% PHP - 16.14% MySQL) with 10 queries
