The woofer needs to be around 8-10" - and a sensitivity of around 95 or so.. any ideas?
#2 |
What price range?
#3 |
Look out for semi pro drivers, prices ranges from US$130-250, brands such as Beyma, B&C, PHL are very good obviously some are more suitable depending on your design. I am using PHL drivers now. Sensitivity ranges from 93-98dB.
If you are conscious of the price then the Eminence Alpha 8 is good value at about $80 each. Cheers. |
#4 |
Check out "www.prodance.cz", click on "English" on the left then click "MLSSA Data" at the top. You will see that there is a range of sizes and makes. This provides a good guide of the measured results.
As well as the Alpha 8, you could add the Beta 8 and Alpha 10, the latter is favoured by Wayne Parham of "Pi Speakers". It all depends on how you want to use them. Roy |
#5 |
Thanks! will look at those.
I want to marry a bass reflex with a mid horn- crossover point will be quite high, around 350 hz or so. the mid driver has a low sensitivity, around 85 or so- no idea what boost the horn will give but guestimate would output around 93-95. |
#6 |
The TD10M could work quite well for that application. We'll have a TD8M within a month or so that is actually a little higher efficiency.
TD10M - 8ohm Fs: 40.5Hz Qms: 2.7 Vas: 59L Cms: .35mm/N Mms: 44g Rms: 4kg/s Xmax: 6mm Sd: 345 Qes: .26 Re: 6.6 Le: .2mH Z: 8ohm Bl: 17Tm Pe: 500W Qts: .23 1W SPL: 93.9dB John |
#7 |
If you can accommodate a 15" driver, Eminence' 3015LF is hard to beat for price and performance.
Sam |
#8 |
a bass reflex (vented box) with 95dB/W @ 1m from an 8 or 10inch driver is likely to have a high bass roll off frequency. You may have to go to a very big box or to 12 or 15inch to get bass extension and good sensitivity.
regards Andrew T. |
#9 | |
He should post what he will be using this for, there are different designs out there that have different goals. |
#10 | |
My proposals: 1) Audiom 12AX Strassacker: Lautsprecher - Boxen - Selbstbau (see also attachements from one of my projects) 2) TAD TL-1102 TL-1102 Low-Frequency Loudspeaker - Pioneer TAD - Prof. Speakers 3) various models of formerly brand Lambda - check out this thread: Who has overtaken lambdacoustics - some user tell: "The best bass I have ever heard" 4) Monacor SPH200 (especially recommend for small chambers as closed box) MONACOR INTERNATIONAL:New products All transducers have one important feature: low loss suspension (High QMS values) |
| High sensitivity Loudspeaker | Lutz_RE | Multi-Way | 4 | 6th March 2008 06:52 PM |
| New to DIY... Looking for something w/ high sensitivity. | DonoMan | Multi-Way | 25 | 10th February 2005 02:58 AM |
| high sensitivity 2way | rebojorge | Multi-Way | 15 | 22nd April 2004 06:08 PM |
| High Sensitivity drivers...Where? | EngelholmAudio | Multi-Way | 28 | 30th April 2002 02:11 AM |
| Page generated in 0.11204 seconds (79.29% PHP - 20.71% MySQL) with 11 queries |
