Old 27th March 2010, 09:38 PM   #1
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Default Score! Dynaco A25s for $4 each!
Pretty happy with my thrift store find today. A pair of A25s for $8. They need tweeters, but still...
The woofers look good and the cabs are OK, but need some work; some scratches, but no gouges.
I'm happy. They had a pair of Apex 710s, but didn't have them priced yet. I don't know much about the Ampex, but the Dyancos... I'm happy with my haul!
Mike
Marantz PM8003 amp, HRT Music Streamer II DAC, Squeezebox Touch, DIY Krystals
Old 28th March 2010, 05:52 PM   #2
Inductor's Avatar
Congratulations. (one good opportunity like that in life is enough in speaker world)
I bet you are going to buy new cap (and tweeters). Please post right sequence of resistors from L-pad/xover (or complete xover) when you can, to check with mine. Some posters (xover) on the net differ in this case (or the year of the speaker, I don't know). It's possible to find similar tweeters if not interested in changing xover. Anyway different tweeters, different xovers. Knock Knock, also very good wood.
My sequence
Old 28th March 2010, 06:37 PM   #3
The woofers sounds great in OB.
Remember that the VC is wound directly on paper so they have no power handling what so ever.
Here are the TS parameter from mine. (A50 built by some * as a kit, good thing the speakers was in nice condition.)
Got it for cheap.
SEAS 25 TV-EW
FS 30.71
Re 12.2
Qt 0.66
Qes 0.74
Qms 5.52
Mms 31.81g
Rms 1.111836 kg/s
Cms 0.000844 m/N
Vas 126.69 L
Sd 326.85 cm^2
Bl 10.03
Lp(2.83V/1m) 87dB
didn't do a wide enough sweep to get Le.
Old 30th March 2010, 12:51 AM   #4
Inductor's Avatar
Originally Posted by David_Web View Post
Here are the TS parameter from mine. (A50 built by some...
SEAS 25 TV-EW...
Re 12.2
Doesn't look like the same Re from the A25 (SEAS 25 TV-EW) woofer. (Don't know how much it is, says 4 Ohm on 1970 specs) The 10" is referenced as SEAS H336 (maybe an 8 Ohm?). Standard impedances are 4, 8 and 16 Ohm.
Some A25 considerations. Link: http://www.audiokarma.org/forums/showthread.php?t=56500
preamp suitable for Dynaco st-70- OTHER than dynaco namatjira Tubes / Valves 3 22nd December 2011 01:21 AM
stacking dynaco a25s through and sca-35? new to this... coot Multi-Way 1 13th July 2009 10:19 AM
Decent Score mikje Multi-Way 1 27th August 2008 05:40 AM
Score? bulgin Tubes / Valves 8 28th April 2007 05:52 PM
HELP - I need a score card!!! russbryant Pass Labs 1 16th October 2002 11:42 AM
Page generated in 0.07830 seconds (74.41% PHP - 25.59% MySQL) with 11 queries
