Old 25th March 2010, 10:17 PM   #1
Ross T is offline Ross T  United States
Default Newbie needing help to trouble shoot.
Hey guys,
I am a newbie here, and I have very limited skills. So, I'm hoping for some help as to what should I direct my attention towards IE: the speakers..? and or x-overs...? and also how to perform any testing and what eqpt. I may need. The speakers are Boston Accustic HS 460's. The midranges, and tweeters, in both speakers went out at the same time. Any help, ideas, or input would be greatly appreciated.
Thank you in advance,
Ross T
Old 26th March 2010, 12:30 AM   #2
test the drivers (out of circuit) continuity with an ohm meter;
If you don't have an ohm meter, briefly connect a 1.5v battery across the terminals and see if you get a click...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 26th March 2010, 01:40 AM   #3
Speakerholic
Cal Weldon's Avatar
Hi Ross,
As Peter says. That will give you your starting point. From there you can work on the XO components if the drivers prove OK.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 26th March 2010, 02:05 AM   #4
kimbo is offline kimbo  Australia
kimbo's Avatar
Hmmmm....both speakers went out at the same time.......could it be the Amp? It's a long shot but I'd eliminate that possibility by either connecting the Bostons to an alternative amp, or connect alternate speakers to your current amp and have a listen. Are you hearing full range?
newbie, needing help with vintage capacitors? Joshua_j Parts 8 10th April 2009 06:32 PM
Newbie trouble- First Amp Project TDA1517 dj_oatmeal Chip Amps 19 1st October 2008 11:56 PM
Newbie Needing Project Design Advice cwoodall Everything Else 1 23rd August 2005 04:27 AM
newbie needing some advice TheDarkside Parts 4 13th November 2004 07:51 AM
Page generated in 0.08270 seconds (75.51% PHP - 24.49% MySQL) with 10 queries
