Old 24th March 2010, 11:21 AM   #1
StigErik's Avatar
Default Loudspeaker drivers in push-pull
We see quite often that woofers are mounted in a push-pull arrangement. A popular example is the Linkwitz Orion, where the woofers are facing opposite directions.
Its been claimed that 2. order harmonic distortion is reduced.
What else will happen, or is expected to happen?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 24th March 2010, 11:42 AM   #2
Inductor's Avatar
The Pi 12 kit (diy) is a good example of one of the best subs in the world, from Wayne P. at Pi Speakers.
(picture from WP@PS: Pi Speakers - unmatched quality and state-of-the-art performance)
Old 24th March 2010, 11:57 AM   #3
StigErik's Avatar
Good link, thanks a lot.
As I suspected, even order distortions (2nd, 4th and so on) is reduced, while odd order (3rd, 5th ...) remains unaffected.
Its interesting that the distortion reduction with push-pull is affected by the air loading of the driver. IB or OB woofers benefit the most, while boxed woofers benefit less from push-pull.
Old 24th March 2010, 12:08 PM   #4
StigErik's Avatar
A conclusion here could be that drivers with very low 3rd harmonic distortion is preferable in push-pull configs.
The drivers I'm using have 3rd order distortion 10-15 dB below the 2nd order. Great for push-pull!
"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? tiefbassuebertr Solid State 68 26th December 2011 07:17 PM
Push-Pull drivers for array? ted4412wilt Multi-Way 1 26th January 2009 03:27 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Parallel Push Pull Drivers gingertube Tubes / Valves 14 13th May 2005 01:32 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.06881 seconds (73.72% PHP - 26.28% MySQL) with 11 queries
