Old 23rd March 2010, 11:19 PM   #1
gabrielbecheanu's Avatar
Send a message via MSN to gabrielbecheanu Send a message via Yahoo to gabrielbecheanu
Default Ascendo speakers
Hi
I would like to start an interesting project, to clone an Ascendo M-F2 or Z-F speakers. Seems to be easy if you have the necessary information. Anyone can help me with a service manual or with other information about the drivers or crossovers diagram, also a schematic of the speakers cabinet will be nice.
Old 23rd March 2010, 11:51 PM   #2
picowallspeaker's Avatar
Nice find. Googling for Ascendo M-F2 speakers you'll find the user's manual ,in which are described the characteristics . The tweeter is visibly the 7" Hi-vi ribbon with the little waveguide ,the mid-wf wouldn't be too much difficult to find 'cos it's got the copper phase plug , the big woofer inside is well hidden ,probably it has some resistors wired in series with the coil (double?) because it's specified that you can select the correct impedance matching with the amp.
http://lauferteknik.com/support_docs...-Manual_en.pdf
Old 24th March 2010, 07:38 AM   #3
Hi
Thanks for the tips. I have a general idea about the speakers but precise information will be greater especially for the bass cabinet also the inside position of the bass driver is important.
Hope to find those information’s before to start a project like this.
Old 24th March 2010, 08:03 AM   #4
Joschl is offline Joschl  Germany
the manual states "Inner Chassis: 28 cm, Hexacone diaphragm".
Therefore it has to be this one (ETON 11-581/50HEX)
n/a
or a special unit made by ETON for ASCENDO.
I would like to see that project
Best regards
Josch
Old 24th March 2010, 08:05 AM   #5
I found the same informstion but you was faster them me
I think the woofer is Eton 11-581/50 11" Hexacone Woofer, the midrange driver i think is Seas but specially made for ascendo.
Old 24th March 2010, 10:29 AM   #6
norman bates's Avatar
ascendo modified the hivi rt2h ($76.60 from partsexpress).
"The tweeter is completely disassembled and modified prior to installation. The upper crossover point is specified at 3kHz."
System z used 2.2khz crossover point with that tweeter.
the seas excel 8" driver (hard paper) perhaps can use the nextel W22NY-001 (E0045), you'll have to correct that rising response.
SEAS Excel W22NY-001 (E0045) 8" Nextel Cone Woofer from Madisound
schematic of the cabinet ?
I'd bet that it is a bandpass in there, no way it is aligned, most are between 20-40ms group delay.
And also good luck building the crossover.
They must get a 24db acoustic slope from adding an 18db electrical to the driver's rolloff.
24db is only time aligned at the crossover point, but much better than a 12db or 18db though.
Overall I'd say this would be a very advanced build.
Norman
Studio monitor speakers as Hi Fi speakers? MRod Multi-Way 2 27th March 2009 05:07 AM
Built differences between Guitar Speakers and PA Speakers? agadis PA Systems 7 24th September 2007 08:22 AM
FS : Studio One Pi Speakers aka Fred's EZ speakers Cacophonix Swap Meet 6 10th September 2007 10:56 PM
How would you compare your DIY speakers to commercial speakers? AJ Bertelson Multi-Way 20 28th May 2004 03:20 PM
Car Speakers in Theatre Speakers NEED HELP FAST!!! Psionic Multi-Way 9 3rd March 2003 11:11 AM
Page generated in 0.08285 seconds (79.11% PHP - 20.89% MySQL) with 10 queries
