Old 23rd March 2010, 11:57 AM   #1
otto88's Avatar
Default Field coil speakers: varying Qes
I have some questions about field coil speakers/ Qes trade-offs.
For a given driver where Qes and Qts is much higher, is anything “lost” in the trade-off, or will any other parameters that effects the sonics change?
Eg with the lower Bl, transient performance??
Situation:
I’m seriously considering getting a pair of the Supravox 215-2000 EXC, very expensive but highly recommended by several who I respect and trust. (It’s wide range, but these questions would apply to any field coil speakers) There are two versions:
The standard EXC version with (depending on power supply volts) Qts variable between 0.25 and 0.34. At 9 V it’s 0.31, with a spec of “98 db”.
The open baffle version with much higher Qes. eg at 9 V the Qts is close to 0.8. It’s not listed on the Supravox website and TS parameters aren’t available . . (I believe they have the same efficiency, though am not sure; and I believe they have the same Xmax, but also - not sure)
I’m doing an open baffle, but because I have very good (2 * 12 inch a side) open baffle ‘subs’ which can work well up to 160 Hz, don’t need the extended bass that the higher Q OB version can provide.
I'll be using a SET amp in a large (long) room, so preserving/ high sensitivity is desirable.
Old 23rd March 2010, 03:13 PM   #2
otto88's Avatar
Default other changes?
I've done some searching:
Apparently the high Q version is -1.5 dB than regular version.
Any other likely changes?
Supravox 215-2000 EXC field coil speakers (pair) xcortes Swap Meet 1 12th January 2011 08:24 PM
Has anyone DIY a Field coil? OzMikeH Full Range 18 16th November 2010 01:56 PM
field coil vs. pm??? Fr34k5h0w Full Range 84 3rd April 2010 04:10 PM
Sensitivity of Jensen A-12 field coil speakers korneluk Full Range 1 24th March 2008 06:05 PM
Looking for jensen field coil Kris9999 Multi-Way 2 10th February 2006 04:31 PM
Page generated in 0.06999 seconds (69.62% PHP - 30.38% MySQL) with 10 queries
