Old 22nd March 2010, 02:57 PM   #1
jmar is offline jmar  United States
Default Tweeter dispersion
On a typical soft dome tweeter (I have the Vifa D27) what are the dispersion characteristics (generally) like?
I mean like the angle of the radiated sound.
Is it fairly constant across the entire surface area (probably is, I'm guessing) or does it behave in a non linear fashion?
Like an LED lamp for example would have equal output "up to" a 120 degree viewing angle. (with zero being on axis, I guess and (2) 60 degree angles for each side.
I really like the way my tweeter sounds mounted BEHIND my baffle but concerned about the size of the hole to use.
THANKS.
Old 22nd March 2010, 03:21 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
There's been a lot of discussion around directivity. Generally tweeter domes are near omnidirectional until about 5k where their beamwidth tends to slowly taper. You want to smooth the baffle cutout as much as possible and create a shallow, flared, 3/4" deep waveguide or the like, to minimize negative influence of mounting behind the baffle. Look up "Basslines waveguide" here and on parts express techtalk- you can find some experimentation with baffle-thick waveguiding.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 22nd March 2010, 03:37 PM   #3
Ok great.
A real difference with this mounted behind the baffle -- using a Pioneer B20 full range for woofer and no doubt that has something to do with it.
Just enough time delay in the Vifa highs to balance things well.
I'll check out that info -- thanks.
Bottom line though -- the damn thing sounds better that way.
Old 22nd March 2010, 03:39 PM   #4
Spatz is offline Spatz  Germany
All speakers are radiating omnidirectional at low frequencies und start beaming at higher frequencies. The speakers usually start beaming at a frequency which wavelength is around the circumference of the diaphragm (ka=1; ka=circumference of diaphragm/wavelength of frequency). Dome tweeters tend to beam at higher frequencies (ka=1,5) but they are beaming stronger above ka.
Beaming is further influenced by the baffle (size, shape, edges), horns, other sound sources (dipoles etc.).
Your comparison with a LED is not right, as a LED is beaming in its whole frequency range.
You can have a look at the software "AxiDriver", which can simulate the sound propagation of waveguides ans horns.
Bye,
Spatz
Old 23rd March 2010, 03:25 PM   #5
I would think for a 1" dome that a 3" diameter hole is plenty (for 3/4" plywood) even without a flare? I'm not crossing the tweeter till about 8K or so because of the Pioneer full range so that's an advantage also.
It sounds good anyway and from all angles.
Old 23rd March 2010, 03:56 PM   #6
Custom Title
badman's Avatar
You're setting up diffractive edges and cavity resonances. There's a reason I mentioned doing a small waveguide...
Old 29th June 2010, 12:39 AM   #7
tinitus is offline tinitus  Europe
right
and thats what Im doing right now
btw, its for "old" Vifa XT19
faceplate been modified
Old 29th June 2010, 12:52 AM   #8
Inductor's Avatar
Originally Posted by jmar View Post
...Like an LED lamp for example would have equal output "up to" a 120 degree viewing angle. (with zero being on axis, I guess and (2) 60 degree angles for each side.
A LED has half the output (or lumens) at the designated angle, so (would) not (have) "equal output", from what I understand.
In general, how to get good dispersion? cuibono Multi-Way 2 26th August 2008 07:45 AM
2 tweeters for vertical dispersion? Ang Planars & Exotics 2 19th April 2007 04:10 AM
Dispersion Modification Methods Tenson Multi-Way 3 29th May 2006 05:43 PM
speaker dispersion malcom_xavior Car Audio 2 14th December 2004 09:23 PM
Baffle width vs dispersion Vg Multi-Way 5 13th October 2003 06:34 PM
Page generated in 0.10234 seconds (82.44% PHP - 17.56% MySQL) with 11 queries
