I have four pAudio HP-10W 4 ohm speakers that I want to use in a pair of recycled speaker boxes.The calculations I've done for one driver come out as 51litre box volume,with a port diameter of 6"(15.24cm) and length of 9.57cm.F3 woks out at 49.01Hz.Searching the archives reveals that two drivers need double the volume,but that any large volume can be adapted.
The boxes I have are 60.5litres.Can I put two of these drivers in each box and will the port size need changing? Driver specs are: Impedance 4 ohm Sensitivity 96 dB Fs 48.43 Qes 0.44 Qms 5.90 Qts 0.4 Vas 55.35litres Xmax 3mm Thanks for your help Paul PS: What size box and port would you recommend for a new build? |
#2 |
download Unibox or Winisd, both free & easy to use,
& work it out for yourself...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
| designing a sub and fullrange box for several speakers... | mulletdude | Subwoofers | 116 | 17th July 2009 04:31 AM |
| box replacement for powered speakers | tilroh | Multi-Way | 1 | 12th May 2008 02:58 AM |
| Got a box and speakers but need help with the insides. | nubbins | Multi-Way | 0 | 18th October 2007 11:24 AM |
| Sonic T-amp and RS40-1354 speakers, now which speaker box? | gychang | Full Range | 12 | 26th August 2006 02:52 PM |
| Can car speakers work in a box? | maylar | Multi-Way | 6 | 19th January 2004 11:34 AM |
| Page generated in 0.08045 seconds (72.71% PHP - 27.29% MySQL) with 10 queries |
