Old 20th March 2010, 06:05 PM   #1
ksporry is offline ksporry  China
Default speaker advice
Guys,
I got a Meng X1 amp. Supposed to have 24 Watts. I've bene playing it on my CDM 7NTs, but those are not very sensitive and need about 50-120 Watts to drive normally.
It works at the moment, but I do have to crank up the amp quite a bit!
I was thinking of getting something else, something more sensitive for the tube amp. Say, in the 95+ dB region.
Can anyone advice me of some good options that don't break the bank? I was considering in price region between 200-300 GBP if possible. Second hand is acceptable too, and I would also consider DIY, though I don't really have much time in the coming months, and depending on the coming month, maybe not for another year and a half!
Anyway, I'd still consider DIY though...
Oh, and preferably not too big!! MY CDM 7NTS are quite big, so something smaller than that, maybe bookshelf size? but if that's not obtainable, then a bit bigger than that would have to do...
Old 20th March 2010, 06:47 PM   #2
High efficiency and small size do not really go together, at least not if you also want any meaningful bass extension.
Old 20th March 2010, 06:49 PM   #3
Glowbug is offline Glowbug  United States
Glowbug's Avatar
If you want good bass extension, small and high efficiency together will be working against you. Can't fight Hoffman's Iron Law.
I know you posted this under Multi-Way, but what about single full-range drivers? A Fonken cabinet with a Fostex driver would be small & high-efficiency.
Edit - too late
Jim J.
Old 20th March 2010, 11:11 PM   #4
Ok, so as I said, I'm not too hung up on size of the speakers. Which ones can be recommended?
PS, I'll place a similar post on the full range forum...
looking for advice on a first speaker project farkus888 Multi-Way 10 25th April 2007 10:05 AM
Advice on sub-sat speaker basharathakram Multi-Way 0 5th May 2005 03:48 PM
Speaker Placement Advice HTRookie Multi-Way 1 20th April 2005 04:57 AM
My first speaker project. Any advice? Jim85IROC Multi-Way 10 14th December 2003 04:11 AM
Need Advice for Speaker Project Tophet1 Multi-Way 2 11th August 2003 08:39 PM
Page generated in 0.06500 seconds (75.28% PHP - 24.72% MySQL) with 10 queries
