A few years ago, I quickly built a pair of speakers. Both the tweeters and woofers were surface mounted. They sounded good enough and I had no time to work more on those, so they stayed that way (with a quick painting job on the front baffle).
I'd like to properly finish the front baffle now, so that the drivers would sit flush. As both the tweeter and woofer protrude by 4mm, the easiest would be to glue on the front a 4mm thick panel with cutouts. I was thinking about cork. It's rather widely available as floor tiles/rolls, easy to cut and some varieties aren't too ugly. Is it a good idea or not ?
Ben. |
#2 |
Custom Title
It's a great idea. Cork is acoustically absorbent and will be very good for this purpose.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
you can also try neoprene, as in the JBL XPL200
#4 |
Or you could try thick felt, similar to the Acoustic Research blanket
I'm fairly sure Wilson Audio use something similar with the Watt (Wilson Audio Tiny Tot) which is now on system 8 along with the Puppy.I think the cork would be a tad easier to keep clean though
"Never let your morals prevent you from doing what is right!" Salvor Hardin |
#5 |
I'd go with cork, looks better.
Tannoy done that during the '80s on some of their domestic speakers and it looked quite nice. |
#6 | |
#7 |
Allright, cork it is.
Now, I've just have to find some in Brussels. PS: I've to say though that neoprene sounded intriguing. It isn't that expensive either. My front baffles are 25cm/93cm. It would have cost 38€, shipped: Fabrics : Neoprene : Neoprene 4 mm rubber without fabric / Shelby - Extreme Materials & Gear
Ben. |
#8 |
#9 | |
Custom Title
Soft isn't the issue. Breatheable, aka acoustically absorbent, is what we want.
| Cabinet w/Hardwood front baffle | caz | Multi-Way | 4 | 12th July 2009 01:04 AM |
| curved front open baffle | pforeman | Full Range | 0 | 20th February 2009 01:38 PM |
| 3-way with tilted front baffle | Twisted85 | Multi-Way | 24 | 11th March 2008 02:28 PM |
| Effect from front baffle material? | Oscar | Multi-Way | 22 | 14th August 2003 09:29 AM |
| ideas for speaker baffle treatment? cork? | bbaker6212 | Multi-Way | 18 | 20th November 2002 05:05 AM |
| Page generated in 1.50195 seconds (7.91% PHP - 92.09% MySQL) with 10 queries |
