Old 11th June 2003, 05:37 PM   #1
JDeV is offline JDeV  South Africa
Thumbs up Successful Repair
I recently "undented" the dustcap of a speaker with a vacuum cleaner. It was quit easy, like this:
1st tried to suck out the dent with nozzle only. Did not work. Then cut off the neck of a plastic bottle and put it inside nozzle. Then closed "sucktion control" fully. Dent then slowly start coming out. About 30s later it was almost 100%.
Thanx for advice from walker, BAM and JOE DIRT®
Before and after:
"Be carefull who's advice you buy, but be patient with those who supply it."
From Baz Luhrmann's - Everybody’s Free (To Wear Sunscreen)
Old 11th June 2003, 05:57 PM   #2
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
you may be able to get rid of the remaning smaller dents using some sellotape. It's worked well for me in the past...
Old 15th June 2003, 04:25 AM   #3
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
I've found that, as the plastic relaxes, it goes back to circular on its own...
Old 15th June 2003, 05:39 AM   #4
JOE DIRT®'s Avatar
your welcome JDev....Cheers to you!
Old 16th June 2003, 12:12 AM   #5
Bose(o) is offline Bose(o)  Canada
Vacuums are great! I punched in the cone on my brand spanking new Audax HMs after mounting them in my enclosure. But, as I lifted the speaker (with screwdriver in hand), I noticed the the cone was popped in...F (fill in blanks). Grabbed vacuum that Mom had told me to put away hours later...and voila!
Moral: Don't buy new drivers if you put your vacuum away, you won't get the ingenous idea of using it.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 16th June 2003, 01:46 AM   #6
apassgear's Avatar
You could do the same to tweeters using a straw and sucking with your mouth
ProCo Rat DIY Not Too Successful orson198305 Instruments and Amps 12 17th June 2006 04:48 PM
Another successful GM JX92 ML-TL _henry_ Full Range 17 27th December 2004 12:14 PM
Copyright ©1999-2013 diyAudio
