3 Way Crossover Upgrade Question
Old 15th March 2010, 04:06 PM   #1
sgerus is offline sgerus  United States
Default 3 Way Crossover Upgrade Question
Hello,
I’m a DYI amp builder interested in upgrading the crossovers in my Klipsch KLF20’s 3 Way speakers
The amp I use is a 2A3 tube amp…. About 3 watts per side
The factory crossover topology is, 2nd order for the woofer, 1st order for the midrange and 3rd order for the tweeter with the xover points at 750Hz and 7000KHz
Based on what I have learned so far, it looks like the typical “upgrades” are
1. Replacing the capacitors with higher grade units
2. Replacing the inductors with heavy gage air core inductors
3. Replacing the autoformer with the Cites universal unit
4. Replacing the 40 ohm resistor across the tweeter with a .15mH inductor
My questions are:
1. Are there any other ideas of upgrades other what I have listed
2. Has anyone used a zobel network on the woofer’s
3. How does the autoformer work? Does it act as 2 inductors, one inductor in series with the midrange and one inductor across the midrange?
4. Any special considerations for using a tube based SE amp
Thank You
3 Way Crossover Upgrade QuestionHide this!Advertise here!
Crossover Upgrade for Morel Duet rean1mator Multi-Way 5 7th April 2014 02:59 PM
Crossover upgrade help!! elves1111 Multi-Way 7 20th July 2009 06:10 PM
Crossover upgrade question serengetiplains Multi-Way 3 5th May 2009 03:09 PM
Kef Reference two, crossover upgrade...possible? bramdo Multi-Way 4 1st April 2007 04:23 PM
Upgrade Crossover Network? bombshell Multi-Way 1 11th August 2004 07:25 PM
