Old 14th March 2010, 11:55 PM   #1
Default Sensitivity training
I now have P Audio coaxials in my K15 Karlsons with the aim of also using the cabs as the bass driver in a 3 way set up with an active crossover.
My P Audio BM15CXAs are rated at 101db for the woofer/106db for the tweeter spl@1m.
I want to bypass the tweeter and use just the coaxial woofer in the K15 with a separate midrange cab and tweeter on top of that.
I would like to know if matching the sensitivity of the mid driver to the woofer(or tweeter) is as big of an issue if I'm using an active crossover with attenuation capabilities for each of the three bands.
My Amt-1 tweeters are 92db spl@1m
I already have a pair of Focal6W252B 6.5 midrange drivers that fit right into my mid cabs now.They're sensitivity is 88.3db@1w1m
It was recomended to get the Audax PR170MO 6.5s with their closer 100db sensitivity.
I would have to alter my cutouts on the cabs to install them however.
Can I just try the lower sensitivity Focal 6.5s and attenuate the woofers/tweeters with the crossovers to match volumes or does the sensitivity have to match much closer than 88.3 vs 101db even with an active crossover (Linkwitz Riley 24db Carvin 3 way stereo crossover).
I'll be using this system in a 15 x20 room. Amps are older Bryston 2bs all around (two amps bridged for each of the woofers)
Thanks for your help.
Old 15th March 2010, 12:04 AM   #2
tinitus is offline tinitus  Europe
I would find a mid driver that matches you 92db AMT
You need to calculate with BSC in the midbass
Avarage 94db seems a good target
Old 15th March 2010, 12:06 AM   #3
Thanks, I'm a novice what is BSC?
Old 15th March 2010, 01:32 AM   #4
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Baffle step correction
Jim J.
Old 15th March 2010, 12:55 PM   #5
doug20 is offline doug20  United States
B&C 6MD38 or PHL 1120 might be a great match for that both are in the 94dB sensitivity area.
Old 15th March 2010, 09:41 PM   #6
My pre made mid cabs are actually sealed surround type cabs.They are 18" wide,10" deep, and 8"tall with a 6.5" woofer and two 4" tweeters on either side.
I'm going to plug the tweeter cutouts.They are shaped like Bose(orange section like) etc.so there will be more baffle out to the sides wrapping around to the rear and there is plenty of room to slide them back and forward on top of the Karlsons for my hillbilly BSC adjustments.
I've read that the Audax PR170MO have over rated sensitivity specs (more like 95-96db) so maybe they'll be in the range no?
My experience with Neodynium magnets is with guitar amp speakers and while they are light and efficient they seem harsher to me.
The PHL1120s seem like top notch units but them mounting would be tricky as while their screw holes are out about 7.4 inches the rest of the actual rim is less than 6.5" and my cab openings are 6.5".
If I can't find speakers that will drop right in my 165mm (6.5") lipped openings I'd prefer to have them overlap all the way around and surface mount them.
Does any one think the Audax PM17 would be a poorer choice compared to the PHL1120?
Thanks again for any and all advice.
Sensitivity pjanda1 Wild Burro Audio 2 12th December 2009 12:54 AM
training ears to like cheap drivers versus Fostex? artfuldodger Full Range 35 21st November 2009 08:54 PM
Tektronix training videos jackinnj Equipment & Tools 0 7th November 2009 01:29 PM
driver sensitivity vs system sensitivity bvan Full Range 12 5th November 2007 07:57 PM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 11:33 AM
Page generated in 0.09179 seconds (74.53% PHP - 25.47% MySQL) with 10 queries
