selecting woofer replacement
Old 14th March 2010, 02:42 PM   #1
gidongidony is offline gidongidony
Default selecting woofer replacement
Hello All
I need a new woofer to replace an old one that isn't made any more (and the damage is beyond repair).
I do not want to make any modifications to the crossover (primarily because I don't know how), so thus want to select the most appropriate new woofer for swap.
I know the obvious things to match: size, 8 ohms, frequency range. But how would you rank order the importance of additional parameters? I have all the parameters for the old woofer such as: Force factor, VAS, QTS, QES, QMS, etc. Which of these values (or any other values) are the most important to match? I can't find a woofer that matches on all measures, but many match on some of the measures, so which are most important to retain?
Please feel free to also just email an answer to gidongidony@yahoo.com
Thanks!
Gidon
Old 14th March 2010, 07:27 PM   #2
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Fs
Vas
Qts
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 14th March 2010, 07:34 PM   #3
event horizon is offline event horizon  England
event horizon's Avatar
Originally Posted by Moondog55 View Post
Fs
Vas
Qts
Agreed, along with sensitivity
Depending on the enclosure type (sealed box would make things easier) you can vary the parameters & still end up with something extremely close. Reflex enclosures would need things more precise
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 14th March 2010, 07:56 PM   #4
Default more info
Thanks for the replies so far, and as i have now learned this is relevant: it is a closed box. To be specific, its a Seas kit 503, and i need to swap the Seas 13 inch woofer...
Old 14th March 2010, 08:22 PM   #5
Loren42 is offline Loren42  United States
Can you have the other woofer measured for its T/S constants?
There are places that will do that, then finding a match will be a little easier.
Old 15th March 2010, 08:11 AM   #6
Default more information
Thanks again for the replies.
Im replacing both woofers, so no need to match the other, just to match the Xover. I have ALL the original specs on the woofer.
g
selecting woofer replacementHide this!Advertise here!
When selecting a replacement tweeter... gripracer Multi-Way 0 20th November 2009 12:33 PM
Woofer replacement glen65 Multi-Way 0 28th October 2007 03:18 AM
woofer replacement blue934 Multi-Way 4 29th April 2007 03:52 AM
replacement woofer koski Multi-Way 4 19th January 2004 03:55 PM
Replacement Woofer DavePobuda Multi-Way 0 4th September 2003 09:02 PM
