Wave guides are all the hot design for home audio right now. Everybody is experimenting with them with everything from 1 inch compression drivers, to modifying them to accept hifi domes. Emerald Physics and others have also gone one step further by incorporating the concept into a large coax.
What are the best coax drivers available to DIY for home audio? Does anybody know which driver Emerald is using? I see most of the pro coax speakers use a 1.4 inch compression driver with big power handling that I won't need and bass tunings for a two way which I would rather cross at 2-300 to the bass drivers. I'm looking for quality over quantity. Any ideas?
Scott |
#2 |
#3 |
Speakerholic
Altec 604 from GPA
Great Plains Audio's Two-Way Loudspeakers EDIT: 2-300 hz will be tough with a coax. Perhaps a good FR and a helper woofer? |
#4 |
Mark Seaton uses Coaxial drivers in his designs (Seaton Catalysts and Sparks), JTR designs use Coax drivers too.
The B&C 8CXT is a decent start, its all about the crossovers in the end anyways. |
#5 | |
Scott |
#6 |
Couple more:
Parts-Express.com:B&C 12NCX 12" Neodymium Coaxial Speaker | 12ncx coaxial neo coxial neodymium coaxial pa woofer Seas Excel 5" Magnesium Cone Coax C16N001/F (E0051) from Madisound SEAS Prestige T18RE/XFCTV2 (H1333) 7" Coaxial, clear Cone from Madisound
Jim J. |
#7 | |
Scott |
#8 |
#9 |
I've used several 12-15" cast frame Eminence - not sure how you would like its horn - - martinsoundpro probably has 1114 12" coax with 80oz magnet and edgewound coil around $120 retail(?) APT50 compression driver will work ok. BMS has some nice looking coaxials over at Assistance Audio - I would have tried one but want lower mms for Karlson couplers
Martin 1114
#10 |
Hi-Vi Research TRINITY6 3-way Ribbon Coaxial:
TRINITY6 - HiVi research 3-way full-range system - EUROPE AUDIO |
| Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? | thadman | Multi-Way | 7 | 11th November 2006 09:11 PM |
| Best 5.25 coax drivers | Zero One | Car Audio | 2 | 9th September 2006 12:47 AM |
| WANTED: Seas Coax Drivers | Tenson | Swap Meet | 0 | 14th April 2006 12:55 AM |
| Add Coax Out to M-Audio Transit? | TerryC | Digital Source | 11 | 22nd February 2006 07:25 AM |
| Replacing factory speakers with HOME audio drivers | seangoesbonk | Car Audio | 1 | 3rd February 2004 04:43 PM |
| Page generated in 0.28310 seconds (35.25% PHP - 64.75% MySQL) with 11 queries |
