Old 8th March 2010, 10:33 AM   #1
otto88's Avatar
Default Open baffle response with tube amps
Using Unibox to model a vented box with a solid state amp, then bumping up Rs (under External components) to estimate the effect of tube amp, usually shows
- sensitivity (max SPL) decreases,
- a lower-mid bass hump increases (warmth/ possible tubbiness is added)
Unibox doesn’t model Open baffles - when a tube amp is used to drive OBs, are the same two effects experienced?
Old 8th March 2010, 11:35 AM   #2
otto88's Avatar
I know in an OB, driver Qts > 0.5 gives better more extended bass.
But if it makes a difference, in my case for > 80 Hz, I’m going to use Lambda mid bass units with a Qts about 0.35
Old 8th March 2010, 11:38 AM   #3
john k...'s Avatar
First, max SPL is dependent only on driver area and excursion. Max SPL at any give frequency will not change. Sensitivity of the driver will not change either. What will change is the the voltgae applied across the driver due to the voltage drop across Rs. Thus, if referenced to the amplifier output (which is what Unibox does) the sensitivity of the driver/Rs system will change.
That said, when used in OB format similar effects would be observed.
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 8th March 2010, 11:46 AM   #4
StigErik's Avatar
That is due to higher total Q and slightly less level loss around the driver impedance peak at Fs. The same thing will happen with OB.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 8th March 2010, 11:46 AM   #5
otto88's Avatar
Thanks John and StigErik, that answers the initial question posted.
Does either A B C Dipole, or MJK's OB worksheet, model the size of the lower-mid bass hump/ driver impedance peak at Fs?
And - haven’t read dipole theory for a few years now: need to refresh!
– isn’t SPL at any given frequency dependent on eg baffle width and the 6 dB/ rise which iirc begins at Fequal?
Old 8th March 2010, 11:52 AM   #6
StigErik's Avatar
Yes, with OB max SPL at a given frequency is also dependant on the effective baffle size.
Old 8th March 2010, 08:07 PM   #7
otto88's Avatar
So it seems that at present we can not model the size and frequency of this lower-mid bass hump . . ie model a crossover driven by a tube amp
Old 8th March 2010, 09:28 PM   #8
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
I believe that MJKs MathCad worksheets cater for an in-line-resistance.
I know that Boxsim does it.
Rudolf
www.dipolplus.de
Old 8th March 2010, 09:58 PM   #9
john k...'s Avatar
To model the hump correctly the full driver impedance in ncessary. The effect of Rs on Qts can be directly calculated and the modified Q input to ABC DIpole, giving an indication of the Q boost. But it will not consider the additional attenuation that occures in the mid band.
Old 8th March 2010, 11:39 PM   #10
CLS is offline CLS  Taiwan
Yes, the key point is the combination of output impedance of the amp and the Re of the driver, thus the Qes is altered, then of course the Qts.
The wording "tube amps" in the topic is somewhat misleading, sand amps can have high output impedance, too.
Here are my previous posts about this: Low Q Woofer in OB with High Zo Amp
Have fun
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open baffle drivers and FirstWatt amps. khundude Pass Labs 1 16th June 2008 03:11 AM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Page generated in 0.13513 seconds (73.33% PHP - 26.67% MySQL) with 10 queries
