Open baffle radiation (FEM method) - Page 2 - diyAudio
Old 9th March 2010, 12:31 PM   #11
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Thanks again sspeaker,
for the improved and diversified simulations. Beginning by the last one - 480 mm circular open baffle - I see that the influence of the magnet (and the V-cone) can almost be ignored, when the cone and magnet diameters are much smaller than the baffle. Your sim is very much in line with my result for a pistonic piston without a magnet IMHO:
If the size of cone and piston are comparable to the baffle, I see much influence that does not get considered by conventional simulations. You already pointed to that.
I don't know how much time and effort I would rob from you - but would it be possible to show, what difference a magnet of larger/smaller diameter or more/less depth would make?
I would predict that making the magnet deeper has much less influence on the forward radiation pattern than changing the diameter of the magnet.
Rudolf
BTW: I understand that a meaningful simulation of the spider would be beyond the scope of this thread. For the time being I just would consider the spider as acoustically rigid - sort of 'front plate' of the magnet.
www.dipolplus.de
Old 25th April 2011, 02:42 PM   #12
I also do some detail measurement recently, below is a 6.5inch pp driver mounted (front flush) in 350mm square baffle. below is the result (5-90deg normalized to 0deg).
but if we used a back flush mounted methods (of cause we need a flare end before the cone), the result seems better.
Old 25th April 2011, 03:13 PM   #13
Old 25th April 2011, 03:44 PM   #14
and a 8 inch in 330mm square baffle (all above also 330mm, not 350mm), the gray is flat baffle (front flush), and the color one is same baffle but with a side brace (like the Linkwitz's Orion).
I think for this width baffle we cannot use a cross point that excess 1200Hz.
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 04:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Copyright 1999-2017 diyAudio
