Old 4th March 2010, 09:12 PM   #1
brdhntr is offline brdhntr  United States
Default Built a box to small
Vas was supposed to be 1.094 cu ft, I built .55 cu ft. I am not a sound guru, so I require very basic responses. My main question is what effect does this have? My perception is not enough low freq. Is this a result of building my box to small? What can be done to limit the negative effect of under sizing the box? Thanks for any input into what may be seen as another annoying novice post.
Old 4th March 2010, 11:11 PM   #2
Inductor's Avatar
You don't say the basics. What is your driver? Maybe we can help. Is like saying you have a car but is not a Ferrari, what's wrong with it's engine.
No problem mate.
Imperial or metric? (I can't see your country) I see it's Imperial, ok.
Please describe the box you already have. (Dimensions int. or ext., Material Thickness, Ports if any)
Maybe this can help as a first approach to the problem
Speaker Box Enclosure Designer / Calculator
Enclosure Volume Calculators (EVC)
Old 5th March 2010, 02:24 AM   #3
Specifications and Small Signal Parameters
Voice Coil Impedance: 4 ohm
Rated Frequency Response: 40 - 5k Hz
Sensitivity: 89 dB SPL
(Average 500 - 2.5 kHz, 2.83V, 1 meter)
Rated Power: 40 watts
Program Power: 80 watts
Magnet Weight: 340 gr (12 oz)
Fo: 45 Hz
Re: 3.5 ohm
Qts: 0.51
Qms: 7.84
Qes: 0.54
Vas: 31 liters
Xmax: 3.8 mm
No: .49 %
This woofer features a polypropylene cone with santoprene rubber surround.
6.57" outside diameter
5.59" cutout diameter
My box is approx 17.5"h x 9.5" x 9.5" external dimensions, and the box is constructed of 1" MDF
This the info on the cross over:
SPECIFICATION:
Type: 2-Way
Crossover Frequency: 5000Hz
Slope: 6dB Low Pass / 12dB High Pass
Impedance: 8 ohms
Power Handling: 150 watts
Old 5th March 2010, 03:43 AM   #4
srinath is offline srinath  United States
I put a 12 inch replacement woofer in a box that was just under 2 cuft. That speaker was ideally designed to go into a 3.2 cuft box. Its calculated response in my box is 38-39 hz, but in its perfect box it would be closer to 28 hz.
That only is where there is a 10 db drop from its curve plateau if I understand. So it will play less loud at the location near the lowest freq. That's it. Also I thinnk the vent for a large box is smaller I believe.
Cool.
Srinath.
Old 5th March 2010, 03:43 AM   #5
Also, box is sealed
Old 5th March 2010, 04:11 AM   #6
MJL21193's Avatar
Yes, the box is too small. It is a closed box, correct?
Not much to do other than make the box bigger.
Old 5th March 2010, 04:21 AM   #7
bastek is offline bastek  United States
Over stuff it, to make the driver Think its a bigger box?
I don't know where i heard that before.
Old 5th March 2010, 04:25 AM   #8
MJL21193's Avatar
That'll give you 10% maybe, not 50-60%
Old 5th March 2010, 04:32 AM   #9
If I built a stand for these speakers, and opened the box into the stand would that work?
Old 5th March 2010, 04:42 AM   #10
frugal-phile(tm)
planet10's Avatar
You aren't going to get much more bass out of that woofer in a sealed box. Stuffing it or making it aperiodic can lower the Q.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Built box too big, how to control excursion? Jameson Styles Subwoofers 1 11th October 2009 05:54 AM
Want a box built for your fostex ? norman bates Full Range 2 11th December 2008 11:12 PM
Ever Built A Parallel Effects Box? turbolx5oh Instruments and Amps 1 27th March 2007 10:55 PM
Monitor built based on box hams Multi-Way 1 30th May 2006 10:19 AM
gainclone built inside atx ps box steven344 Chip Amps 4 22nd November 2005 11:50 AM
Page generated in 0.16102 seconds (54.85% PHP - 45.15% MySQL) with 11 queries
