Old 4th March 2010, 09:02 PM   #1
jim5763 is offline jim5763  United States
jim5763's Avatar
Default can anyone help me figure out the volume of this triangle
i think these might be able to be used as sub cabinets,but my math skills stink.how do i get the volume of this cab.okay can someone do it for me.
ty
Old 4th March 2010, 09:11 PM   #2
Stuart Easson's Avatar
Send a message via MSN to Stuart Easson Send a message via Yahoo to Stuart Easson
I think you can calculate the volume by multiplying the height by one half the length of one side multiplied by the distance from a peak to the closest point on the opposite side.
You need to choose units of measurement to match the units you'd like the volume described in. ie if you measue in CM then divide the results by 1000 for litres. If you measure in inches divide the number by 12 * 12 * 12 to get feet cubed.
HTH
Stuart
Old 4th March 2010, 09:12 PM   #3
nigelwright7557's Avatar
Half the base times the height times the length.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 4th March 2010, 09:12 PM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
ty
If you take two together, you got the area of a parallepipidum - a recktangle that's skewed. Google the area of a parallepipidum, and multiply with the height. Divide by two. Done.
jd
/Another new issue: Linear Audio Volume 3!
Old 4th March 2010, 09:16 PM   #5
janneman's Avatar
That's it! Much easier than my method!
jd
Old 4th March 2010, 09:16 PM   #6
Loren42 is offline Loren42  United States
ty
1.332 cubic feet.
If you don't believe me, just pour sand into the box until it is filled and measure the amount of sand you have.
Old 4th March 2010, 09:17 PM   #7
jim5763's Avatar
with those formula's i still suck at math,what about those three 1 3.4" corners(i should have stayed in school longer)in pic3
Old 4th March 2010, 09:18 PM   #8
jim5763's Avatar
ty loren
Old 4th March 2010, 09:19 PM   #9
jim5763's Avatar
i'd ask how you came to 1.332 cf,but i would'nt understand it.thanks again
Old 4th March 2010, 09:20 PM   #10
TNT is offline TNT  Sweden
TNT's Avatar
The area of a equal side triangle is hight squared divided by 2 - you get volume by then multiplying with hight (of the thing). Det area is 133 sq in which I derived with my 2D drawing program. den multiplied by hight -> 2127 cu in or 60 litres volume?
Could that be about right?
Can Anyone figure this? duderduderini Tubes / Valves 8 6th April 2008 01:27 PM
trying to figure out a cheap sub setup AutoAudio Subwoofers 14 6th December 2005 01:09 PM
trying to figure out xformer wiring... cowanrg Parts 32 12th November 2005 03:44 PM
Can't figure out Zaph's design... cjnordquist Multi-Way 12 29th July 2005 11:45 PM
help me figure this out please xdissent Solid State 7 23rd November 2003 08:57 AM
Page generated in 0.13631 seconds (65.94% PHP - 34.06% MySQL) with 11 queries
