Old 3rd March 2010, 02:36 AM   #1
Default A little refresher please - Capacitors in parallel
I need a confirmation about the rule that I learned in College too long ago.
When 2 capacitors of 25 uf - 100v are in a parrallel circuit the total capacitance for this circuit will be 12.5 uf at a mximum voltage of 100volts ?
When 2 capacitors of 25 uf - 100v are in a series circuit the total capacitance for this circuit will be 25 uf but maximum voltage of 200volts ?
Theses rules apply to Non-Polarized capacitors also ?
Please refresh my memory, thanks.
Old 3rd March 2010, 03:06 AM   #2
frugal-phile(tm)
planet10's Avatar
Capacitors in parallel sum. 2x25 = 50 uF, 100v in your case
capacitors in series Csum=1/(1/C1 + 1/C2) voltage the sum of the voltages of the caps (12.5 uF, 200V in your case).
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd March 2010, 03:45 PM   #3
Speedskater's Avatar
dave
I'll give the 200 Volt rating a big maybe. Capacitors in series may not divide the voltages evenly. Often a high value resistor is connected across each cap. to help with the voltage division.
Kevin
Old 3rd March 2010, 04:47 PM   #4
frugal-phile(tm)
planet10's Avatar
Always recommended.
dave
Old 3rd March 2010, 07:07 PM   #5
When you say high value resistor what kind of value (in ohms) are we talking about ?
Also how many watt resistor do you recommend, 1/4 w, 1/8 w, 1/2 w, 1 watt, 2 watts ?
Old 4th March 2010, 03:09 PM   #6
I don't remember!
Probably someone in the "Tubes / Valves" sub-forum would know.
Kevin
Old 4th March 2010, 05:23 PM   #7
aud1out is offline aud1out  Canada
Default Ripple current and ESR
Hope this is not off topic.
What happens to ripple current and ESR when you parallel / series?
Old 4th March 2010, 06:47 PM   #8
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
1/2 W should be OK, - calculate the value up to max current without overloading the resistor......
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
linking capacitors in parallel - best practice jscherer Parts 8 17th March 2009 05:34 AM
parallel capacitors in PS question gary h Tubes / Valves 4 26th July 2008 09:06 AM
capacitors in parallel in a crossover Jonasa Multi-Way 3 6th January 2008 09:24 AM
parallel resistors / capacitors in crossover jimbo1968 Parts 4 26th January 2006 05:16 PM
parallel capacitors dstockwell Parts 1 18th November 2005 05:51 PM
Page generated in 2.10890 seconds (4.01% PHP - 95.99% MySQL) with 10 queries
