This is quite an insight on how SL test his drivers. Apparently he drives them to 30v vpp.
Triggered burst measurements of tweeters There is an example of comparison between Seas 25TFFC and Neo3 and how they differ in such application. I know some would argue that these are not audible, but surely if the objective is accuracy then the transducer needs to faithfully reproduce the input signals? Then of course above all things the "wallet factor"
http://gainphile.blogspot.com |
#2 |
It would be interesting if SL would do the same measurements at a frequency the Neo3 actually can handle.... like 3 kHz. We who have used this driver knows its no good below 2.5 kHz or so. The power compression loss seen should be the same though.
30V p-p is A LOT for a tweeter, very tough test this is.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles Last edited by StigErik; 1st March 2010 at 09:26 PM. |
#3 | |
I just refrained from posting the same thing. Here is my though: I don't place much credence on tests done w/o the intended crossover in place.
John k.... Music and Design NaO Dipole Loudspeakers. |
#4 |
Apparently SL likes to cross tweeters very low. 1440 hz for Phoenix and Orion and 1khz for pluto.
"The large amount of distortion at relatively low power level would rule out this driver for my applications, which usually require a low crossover frequency." GR-Research is quoting usable xo point of 2khz and 1khz for monopole or dipole repectively: http://gr-research.com/pdf/NEO3.pdf Zaph mentioned about the ribbons/planar only usable 2.5khz and above: Zaph|Audio
#5 |
His point was that he didn't want to test its distortion using the best crossover point for the driver, but at the crossover point that he requires for his application, hence the low frequency.
That's what he stated at the end of that section. Edit: Just too late to point it out first.
Source: FreeBSD & XMMS on VIA Eden, Terratec Aureon 5.1 / Yamaha GT-CD1 Processing: DEQ2496, 2x DCX2496 Amps: 4x EP2000, 2x EP4000 The Gate, best speakers in the world? :-) |
#6 | |
#7 |
The NAOs uses 2x 6.5" drivers, my assumption to reach certain target SPL? By doing this the baffle can be narrower (as supposed to 8") and hence the tweeter xo can be higher. At what frequency do you cross the tweeters in your design if I may ask?
Higher tweeter frequency is definitely desired as not everyone can afford $300 (times four) Millienium tweeters. What is this "new approach" that you're working on re: tweeter polar response.
#8 |
Hmmm, all very interesting. Very interesting. I hope JohnK will share more.
I've been using the Neo3PDR crossed at 1700 LR4 acoustically. Personally, I like it a lot. I hear nothing I consider a problem yet. Of course, maybe I need more outside references... To bad SL has already ruled it out - it seems like a decent driver to me. Maybe his test is a little harsh?
double complete rainbow all the way!! |
#9 |
Account Disabled
Looks like an apples and oranges comparison.
http://www.seas.no/images/stories/vi...519_25tffc.pdf http://www.radiapro.net/uploads/NEO3WhitePaper.pdf Wonder if Sig looks at the 20 Watt vs. 80 Watt input power and 3.5 vs. 6 ohm nominal impedance before comparing the Lincoln Town Car to a Greyhound bus. Maybe his philosophy goes something like: test first - read specifications later...... |
#10 |
Current Project
http://www.audioheuristics.org/ aka Mark's Speaker Page |
| Neo3 and Neo8 - how should they be used? | Spasticteapot | Multi-Way | 1 | 21st May 2011 01:34 AM |
| SL's Pluto | sdclc126 | Multi-Way | 122 | 22nd January 2011 04:08 AM |
| WTT: BG Neo3 for BG Neo3-PDR | azngotskills | Swap Meet | 0 | 1st December 2007 10:24 PM |
| A Second look at SL's PLUTO | ScottG | Multi-Way | 26 | 25th October 2005 11:48 PM |
| Page generated in 0.21081 seconds (61.04% PHP - 38.96% MySQL) with 10 queries |
