Old 25th February 2010, 11:54 PM   #1
Default Help with TL design
First, a bit about myself. I got into speaker design long, long ago when a friend needed help with some math to make some bass reflex enclosures. Later, I worked for a hifi store. The T/S stuff was introduced, and I heard some really horrible speakers, convincing me that Novak was right all along. In the '80s an engineer friend introduced to me to those little FE-103 speakers Radio Shack sold, and I played around with some open baffle designs matched to sub woofers, satellite/sub systems being the DIY rage back then. Now we're wanting to add some real speakers to our home theatre, and I'm looking at transmission lines as a possibility. We move our furniture around too often for room dependent speakers, so OB designs are out. I've spent the last week reading so many web pages I'm totally lost! While I think I have the gist of it, the one thing I can't remember being mentioned is the importance of the overall (internal) volume of the box. The length relates to the cutoff, and the cross-section... some say it should be no bigger than the speaker, yet in many plans it appears that it is. Can someone help me out here?
Old 26th February 2010, 12:18 AM   #2
frugal-phile(tm)
planet10's Avatar
Usually an optimal TL will have xSection much larger than driver Sd. Keep in mind that there is the old and out-of-date Classic school of design, and the modern, much more accurate design methods that use Martin King's software or tables (Augspurger's software works too, but is not near as well developed)
What driver(s), amp, expectations?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th February 2010, 01:33 AM   #3
mightym is offline mightym  United States
mightym's Avatar
Location: Checotah, Okrahoma former home of the Okra Fest
Have you looked at MJK's TL tables?
Check out the Quarterwave site, his tables are pretty much right on AFAIK.
Transmission Line Theory
You should find everything you need there.
Old 26th February 2010, 04:41 AM   #4
For drivers, I've been looking at the Eminence Beta 12LTA. My amps are Haflers, two MK IIIs, and a more modern stereo 120. I'm not looking for an extremely wide bandwidth, it seems to me dynamics are more important for realism. I figure if I can get down to 100 Hz then crossing over to a sub will be no problem. Does a 12"x12"x34" box qualify as a "transmission line"?
Old 26th February 2010, 06:35 AM   #5
frugal-phile(tm)
planet10's Avatar
A quick look at teh spec and given you are only trying to hit 100 Hz, aperiodic or sealed probably makes more sense.
dave
Old 26th February 2010, 12:48 PM   #6
Thanks, Dave. I suspect you're right. Still, the idea of a transmission line is kinda sexy.
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Best TL Sub Design You Have Seen? Dominick22 Subwoofers 27 30th January 2007 05:32 AM
TL design inrank Multi-Way 3 1st November 2006 04:10 PM
TL design tool? mazeroth Multi-Way 3 22nd May 2006 08:03 AM
Quick help for TL design theChris Multi-Way 14 14th March 2005 06:19 PM
Page generated in 0.13093 seconds (50.70% PHP - 49.30% MySQL) with 10 queries
