Old 25th February 2010, 10:08 PM   #1
Moondog55's Avatar
Angry Improving Polycone woofers
I have been reading Lynn Olsen again and his comments on the performance of most generic polycone woofers.
Has anyone any experience on improving the stiffness of these cones and any suggestions on relatively easy mods?/
The woofers in question are from Jaycar Australia, the 10 inch CW-2137, I have to say that I have only been playing with these naked, but when running more than a few Watts into them they do start to sound quite distorted.
I assume that what I am hearing is edge break-up.
I was thinking of adding felt pads "A La " VAFResearch and if this would aid in stiffening the edges of the cone.
Any thoughts??
I would perhaps use a different woofer if I did not already have a few of these,
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 26th February 2010, 02:10 AM   #2
Hi Moondog, tried PVA? don't know how dammar would work on poly.
Jaycar drivers may be cheap, but with your experience & mine of them, I'm coming to the conclusion that they're not worth the bother (& I've got about a dozen hanging 'round...)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 26th February 2010, 02:30 AM   #3
gainphile's Avatar
Is the distortion in the lower or higher frequency spectrum?
I have a polycone Vifa P13 and was quite surprised of the distortion on the lower frequency. So perhaps it's not a brand but rather material limitation.
http://gainphile.blogspot.com
Old 26th February 2010, 02:50 AM   #4
Account Disabled
This is a fascinating topic and I'm glad someone brought it up. Perhaps there are other threads concerning the "doping" of cones. I have twelve kevlar bass drivers that I've been thinking of coating to reduce the effects of out of band break up - thus allowing a higher crossover point with a more gradual slope.I've seen versions of it in different markets that were "hand coated", but there's not much info on the composition of the coating. Anyone on here have successful experience with applying epoxies or polymers to improve either rigidity, damping, or both? My thinking is a somewhat lite application that will only change mass slightly - causing a modest reduction in transient speed to go along with the lowered Fs......Any thoughts or experiences?
Old 26th February 2010, 02:51 AM   #5
Moondog55's Avatar
Yeah Peter, the problem only comes about when they are pushed to more than a few Watts.
I tried PVA on other Jaycar ploycones and it just peels off.
There is some Jaycar stuff that is really nice to listen to, but they all seem to need OB or bigger boxes than acceptable for WAF.
Hi Gainphile, I really think this is a combination HF breakup? and IM distortion as the edges of the cone start to wobble.
I got these because the 10 inch Carbon fiber woofer is SO GOOD, and on paper they model really well sealed ( for my application at least )
Maybe we should just sell this house and buy an old church, although those are getting very expensive again, they allow plenty of room for big boxes.
Old 26th February 2010, 03:07 AM   #6
frugal-phile(tm)
planet10's Avatar
Most everything peels off polypropelene... you might try etching it with sandpaper.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th February 2010, 03:41 AM   #7
Moondog55's Avatar
Thanx Dave, that was my conclusion; although I read somewhere that superglue gel works I have never tried it.
I just connected woofer to a generic 2nd order XO ( 5.8mH & 150uF ) came out of the Radio Shack sub, and far too much HF still being heard but much better
SO
It must be HF from the steep rising response common to all Jaycar poly I can hear,
Just changed cap value to 250uF, better BUT.
Maybe they will be OK with 4th LR electronic, better get the spareXO out of the cupboard and make some more cables
Old 26th February 2010, 03:46 AM   #8
re:'Any thoughts or experiences? ' - I've used dammar on some old drivers, useful for restoring colour & giving the cones some integrity, but the down side is that the stiffening of the cone gives a peak not unlike a metal cone, but lower in freq & not so high Q.
Old 26th February 2010, 03:49 AM   #9
One thing I was thinking of trying with some old drivers, just for the hell of it - fill the cone up with polystyrene foam, so they end up sort of like a round B139
Old 26th February 2010, 03:58 AM   #10
Account Disabled
Good to know. I've never tried the stuff. I've been looking at some doped copolymers - like a low viscosity epoxy with phenolic microballons added to improve flexibility and strength. Before I start "experimenting" with expensive drivers though, I'm going to consult a chemical engineer on the type and amount of catalyst - I have no idea what heating side effects can do with carbon and kevlar fibers and I certainly don't want to find out the hard way....
Improving my UCD180 Zodiac Class D 13 17th March 2010 02:33 AM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
improving a dayton 8? xstephanx Multi-Way 9 27th January 2006 04:32 PM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
Using DVC woofers as 2 seperate woofers Hybrid fourdoor Multi-Way 2 15th June 2003 12:10 AM
Page generated in 0.22742 seconds (41.49% PHP - 58.51% MySQL) with 11 queries
