Old 25th February 2010, 08:50 AM   #1
el`Ol is offline el`Ol  Germany
Default M-dipoles
Hello all!
In the latest Klang+Ton, a German DIY magazine, there is dipole speaker with an M-dipole. This is how something like this looks like:
Dipol-Bass mit Visaton W 250 für FAST Systeme, Lautsprecher - HIFI-FORUM
It is 38x38x76 cm, drivers are two Peerless SLS 12. It runs from 30 Hz to 200 Hz without correction, just a 12 dB lowpass filter and without sensitivity loss.
My question:
Why is the usual dipole bass two pro drivers on a flat baffle with EQ and a 1000 W amp?
Old 25th February 2010, 09:12 AM   #2
StigErik's Avatar
That Visaton thing does have dipole correction and EQ:
"Erkennbar ist die Anpassung der Filterkurve an den Resonanzbuckel bis 400 Hz. Bei einer steilflankigen Trennung bei 300 Hz oder niedriger wird der Resonanzbuckel ausreichend kompensiert. Ab 200 Hz setzt zu niedrigeren Frequenzen ein 6 dB/Oktave-Tiefpass ein, der den Dipolabfall im Fernfeld kompensiert."
It says there is dipole EQ compensation below 200 Hz and EQ to kill the peak at 400 Hz, in addition to a 300 Hz low-pass.
I haven't read that Klang+Ton article though, but it will be a surprise to see a dipole sub without any EQ!
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Dipoles ? LennyK Multi-Way 111 21st September 2006 03:12 PM
FE166E in dipoles xstephanx Full Range 2 14th June 2006 05:55 PM
3-way or 4-way dipoles? mazeroth Multi-Way 0 25th January 2006 06:37 AM
Spicatto Dipoles Raka Multi-Way 42 6th November 2004 07:00 PM
A first crack at dipoles Roscoe Primrose Multi-Way 12 6th March 2004 08:29 PM
Page generated in 0.09542 seconds (51.59% PHP - 48.41% MySQL) with 10 queries
