Old 25th February 2010, 03:47 AM   #1
Default Driver or design suggestions
I need some suggestions.
I have a friend who has a pair of PE .75 cu/ft 2-way boxes with port holes cut and he wants to load them with something.
He has a pair of Vifa DX25TG-05-04 tweeters which he would like to make use of but not carved in stone.
Budget of about $100.00 for woofers.
The first one that came to mind is the Silver Flute 8'' but I think that needs to be sealed or a larger box, I'm not quite sure.
$36.80
Specs:
Silver Flute 8"
Wool Cone
Cast Frame
38mm VC Ø
Rubber Surround
Vented Pole Piece
F3 of 60Hz in 0.64 ft3 vented enclosure
Re 7.3 Ohms
Sensitivity 91 dB
Power 100 watts
Fs 30.8 Hz
Qms 1.30
Qes 0.28
Qts 0.23
Vas 83.3 Ltrs
Mms 20.9 g
Cms 1281.1 mM/N
Sd 0.0214 M2
BL 10.1 TM
X-max 5 mm
Le @ 1kHz 0.92 mH
Frame Ø 203 mm
Cutout Ø 183 mm
Depth 86 mm
Krm 1.65 mW
Kxm 32.793 mH
Erm 0.853
Exm 0.591
Box Rec.: 16 litrs, 2" Ø V x 4" L
Or:
If someone knows a design that will suit, please chime in.
He has many coils and caps etc. So, crossover parts should be a non issue.
I know this guy quite well. He likes to play fairly loud from time to time and listens to just about all forms of music. He mentioned that he does not like colored sound.(Hmm)
Old 25th February 2010, 04:12 AM   #2
PB2 is offline PB2  United States
PB2's Avatar
Parts-Express.com:Vifa PL18WO09-04 7" Woofer 4 Ohm | Peerless Vifa PL18WO09-04 bass mid midbass mtm poly cone 2-way Tymphany vline logic PeerlessBuyouts612010
Pete Basel
http://www.linkedin.com/in/petebasel
Driver suggestions Marcel_D Multi-Way 3 19th October 2007 09:41 AM
Suggestions for new driver for sub geoffstgermaine Subwoofers 0 8th March 2007 03:17 AM
Suggestions for this driver Flavio88 Multi-Way 5 31st December 2006 01:38 AM
Driver Suggestions renfrey Full Range 3 7th June 2005 07:13 PM
Driver Suggestions bjackson Multi-Way 10 28th February 2005 12:23 AM
Page generated in 0.08660 seconds (66.70% PHP - 33.30% MySQL) with 10 queries
