#601 |
I am not sure that is true. I just decided not to continue in the discussion. I did not believe you were making an effort to understand, you were just playing word games for your own amusement.
#602 | |
All of these enclosures can be modeled by the same math and therefore you don't need to be concerned about boundaries of applicability between models. If you are using one of the simple T/S based models, then you really need to be aware of the limits of applicability with respect to geometry and frequency. Once you step up to a 1D wave equation TL style of model, then you need to be concerned about the other two dimensions and potential standing waves not accounted for across the TL (side to side or front to back) at higher frequencies. The mitigating factor is the stuffing, it will help suppress the modes you are not accounting for in your model so your results will probably still be accurate. With respect to Hornresp, Augspurger's TL program, AJHorn, and my MathCad worksheets; a few years ago I ran tests of my MathCad models against these three other programs. If the same problem was formulated and run the results matched very closely, physics is physics. Each program has its own set of strengths and weaknesses so the user needs to determine what they want to accomplish and then pick the right tool. The accuracy of model results is driven by the knowledge and skill of the user. |
#603 |
Has anyone tried this? COMSOL : Acoustics Module
I have access to a copy (it's very expensive). This does full 3D FEM on arbitrary geometries and it does multi-physics so the thermal effects at LF can be included.
2012, our time is running out. |
#604 |
Not intending to minimize or disagree with the point you're trying to make, Ed, but your description of the second graph is not quite correct IMO. The graph shows the system response with the red line, the outputs of the driver and terminus/port combined in both magnitude and phase, whereas the dashed blue line is how the system response would behave in an infinite baffle arrangement. You need to show the 8th graph in the series to accurately show how the driver and terminus/port individually respond where the red line is the driver and the dashed blue line is the terminus/port. At least that's my thoughts, and if I'm all wet, I apologize.
Paul Quote:
#605 | |
#606 | |
#607 | |
AudioKarma.org Home Audio Stereo Discussion Forums - View Single Post - AK Design Collaborative - Insubnia |
#608 |
...truth seeker...
pkitt,
I appreciate your comments. Together, we'll get it right. I've added them to the things I'll review this weekend. I'm looking forward to diyIndiana. Hope to see you there.
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#609 | |
Hear the real thing! |
#610 | |
I replaced the ANSYS models here with a T-matix model which is far less detailed, but detailed enough, and runs instantly. It will even search hundreds of designs for the best one - something that FEA would have real trouble with. |
| I need some expert help in building | bateman | Multi-Way | 14 | 9th September 2003 12:39 PM |
| Little help from the expert please.... | Mikka | Solid State | 14 | 7th June 2003 03:23 AM |
| Little help from the expert please.... | Mikka | Parts | 1 | 6th June 2003 05:50 AM |
| Little help from the expert please.... | Mikka | Everything Else | 0 | 4th June 2003 09:36 AM |
| Combing effects: How real in "real" rooms? | smeade1079 | Multi-Way | 3 | 10th March 2003 12:32 AM |
| Page generated in 0.22586 seconds (54.44% PHP - 45.56% MySQL) with 11 queries |
