Old 23rd February 2010, 09:25 AM   #1
Default Mission 753's to 3 way?
I've a set of non Freedom Mission 753's. I have an Arcam Alpha 9 setup and just got a 3rd Power Amp.
My 2 current 9P's are Bi-amped, dual mono. Im thinking of adding a 3rd making it tri-amped and tri mono but each amps to drive the different stages of the Missions.
How easy is it to mod or make the speakers and crossovers do this? Im no sparky, i know a few bits and bobs. I've seen a few diagrams about the cross overs.
Pete
Old 25th February 2010, 08:30 AM   #2
Anyone got any advice, done it?
Old 25th February 2010, 01:25 PM   #3
Sonusthree's Avatar
I'm wondering if the 753's are 2.5 or 3 way?
Martin
Old 25th February 2010, 03:58 PM   #4
2 way as they have 2 sets of inputs and from the wiring crossover scymatyic i've seen!
Old 25th February 2010, 07:18 PM   #5
ianpengelly's Avatar
I believe they are 2.5 way, the bottom two speakers being the bass reinforcement.
There is an illustration of the crossover here:
Mission 753 speaker modding - World-Designs-Forum
Old 25th February 2010, 07:44 PM   #6
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
It appears 2 of the woofers have a 1st order high-pass network and a 2nd order low-pass network on them. The other 2 appear to have a 3rd order lowpass network with added series resistance.
Not sure exactly what that constitutes though, technically a 3 way as the midrange is effectively running bandpass, but those asymmetrical slopes suggest it is being used as some sort of BSC arrangement.
Old 1st March 2010, 11:07 PM   #7
So is possible to split them into 3 different amp inputs?
Old 2nd March 2010, 12:15 PM   #8
Dr.EM's Avatar
Looks like you could easily enough
EDIT: See attached
Old 2nd March 2010, 12:35 PM   #9
Loren42 is offline Loren42  United States
Yes, but a standard 3-way active crossover is not going to work. You will need multiple 2-wy crossovers to get the same crossover points and slopes.
Leaving the existing crossovers in place and tri-amping essentially is worthless. The major benefit of tri-amping is getting rid of the passive crossovers so you can directly couple the woofers to the amps. The benefits to doing it this way are too numerous to list here.
Old 3rd March 2010, 05:23 PM   #10
I would not agree about it being
while I would agree that its better to get
their is real benefit to bi-amping and more so than bi-wiring which also shows benefits, even (or maybe especially) with bell wire or cheap speaker cable. All these improvements reduce the woofer's resonances having an effect on the tweeter.
The negative with going active (apart from making/buying an active cross over) is remembering to wire the active crossovers, amps and speakers correctly so you don't send bass to thew tweeter.
I would agree that
Mission ARGONAUT alex-mayer Multi-Way 26 7th March 2012 12:24 PM
I bought bad Mission 753's, T's and x-overs fried, worth fixing? timbert Multi-Way 69 31st May 2010 10:39 PM
Mission vs everyone else. chris661 Everything Else 7 4th November 2009 08:01 AM
mission 780 samtheman23 Multi-Way 0 23rd November 2006 08:57 PM
Mission 701 Sonus Multi-Way 0 6th November 2004 08:25 PM
Page generated in 0.14269 seconds (69.07% PHP - 30.93% MySQL) with 11 queries
