Old 22nd February 2010, 07:49 PM   #1
jcstoke is offline jcstoke  Slovenia
Default Help a noob design a budget 5.1 system
I've been spending quite a bit of time lurking around these forums and just about everywhere I can find info about speaker building and I thought it was time to start asking for some advice for my build.
I'd like to build a complete 5.1 speaker system. I'm looking to keep costs under $300 for everything. I'm also just starting out so an easy forgiving build would be appreciated.
Somewhere I saw an example of a project that combined several different designs into a 5.1 system but I can't seem to find it anywhere (I've been in the research faze for months and I've forgotten what I've found where...).
I'm thinking of some 2 way bookshelf speakers for the front (like zaphs BM4s or HiVi Jrs) and a possibly a full-range design like zaph's Hi-Vi B3S or similar for the rear surrounds. I have no ideas for the center but I'd like for it to fit below my LCD which would need to be less than the following dimensions: 11mmx40mmx8mm (H,W,D).
For the Subwoofer I'm looking at 220 volt options since I live in Europe and I'm leaning toward the CerwinVega Full-Range amp from ApexJr. I believe it's 150Watt but I have no idea what driver to pair it with and what would be a good cabinet design for it.
My Living room is 4.5 meters x 4 meters and I have neighbors living below me so I don't need to rattle the walls, I'm just looking for a reasonable alternative to the complete 5.1 boxed solutions that we have here in Slovenia.
This will all be driven by my 100 watt yamaha receiver if that makes a difference.
Thanks for any input and advice that can get me started in the right direction.
Johnny
Old 22nd February 2010, 09:33 PM   #2
frugal-phile(tm)
planet10's Avatar
5 Mark Audio CHR-70, and 1 or 2 ApexJr Super8 to go with the CV amp
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd February 2010, 09:11 AM   #3
Thanks for the input Dave. I really appreciate it.
Would you suggest the 5 Mark Audio CHR-70 for the front and rear channels? The Mini BR design looks like a simple start for me. If so maybe I should move this thread to the full range forum.
Also, is there a slim box design that would work with these drivers for my center channel given my dimension requirements? 11mmx40mmx8mm (H,W,D)
And thanks for the super8 recommendation. I'll definitely check that out. Thanks again for the help.
Johnny
Old 24th February 2010, 01:44 PM   #4
r0b is offline r0b  Germany
Since this is about the size of half a pack of cigarettes, I suppose the only way to fit a speaker there would be to take apart a mobile phone or a gameboy and use these speakers.
Or were you thinking cm?
Old 24th February 2010, 01:56 PM   #5
Speakerholic
Cal Weldon's Avatar
Me wonders if he meant cm
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th February 2010, 05:28 PM   #6
frugal-phile(tm)
planet10's Avatar
Keeping all the same is a very good idea.
Given that this is in an HT sealed has a big advantage. The work done i've done with these indicates that anything less than 8 litres should be sealed.
If we assume your dimensions are internal, and in cm, we have 4 litres (and an aspect ratio high enuff that you have a half-wave transmission line, with cross-section that will not let the driver breath well). The driver is best in 5-6 litre sealed for your application, if you want to use a box like that it would need to be aperiodic.
dave
Budget subwooofer system Therrol Subwoofers 3 17th November 2009 08:51 PM
Budget T-amp system sub? wakibaki Subwoofers 21 3rd March 2008 02:30 PM
budget dorm system Evazan Multi-Way 10 22nd September 2006 05:18 AM
noob two-way budget project!! help please? guitar012345678 Multi-Way 1 7th January 2005 07:02 AM
Budget for Surround System? CZ Eddie Multi-Way 4 23rd November 2003 10:09 AM
Page generated in 0.11942 seconds (66.05% PHP - 33.95% MySQL) with 10 queries
